M2 Technical Topics > Track / Autocross / Dragstrip > Track pad wear
      09-28-2017, 09:54 AM   #1
ZM2
2811
Drives: 2017 LBB M2
Track pad wear
Hey guys.
I’m starting to get uneven wear on my track pads. My front right outer track pad was worn to the backing plate on the leading edge; trailing edge had 1/2” pad left. Now I have to trash them after just one track day bc of either a sticking piston or caliper flex?
What do you guys think the cause and fix is for this?
Thanks.
      09-28-2017, 11:47 AM   #2
dvas
dvas's Avatar
518
Drives: 2017 M2 - Mineral Gray, 6spd
That sounds like extreme uneven wear. I've never encountered something like that before.
Sounds to me like a sticking piston to me but I'm no expert. I'd start troubleshooting and try having someone sit in the car and very slowly step on the brakes with no pad in that caliper and observe to see if all of the pistons get pushed out uniformly.
      09-28-2017, 08:55 PM   #3
M+M
M+M's Avatar
New Zealand
227
Drives: M2 DCT MPerformance coilovers
Agree sounds very extreme and something is definitely not right. The trouble with calipers not designed as motorsport calipers is that even if you use a motorsport pad the design and spec of things like the piston seals means that they do not last very long. So seals can fail from heat allowing dust and grit to begin penetrating.
      09-28-2017, 11:01 PM   #4
lax01
793
Drives: 2017 M2
Did you stomp (and hold or even rest) on the brakes after coming off track?
      09-28-2017, 11:27 PM   #5
ZM2
2811
Drives: 2017 LBB M2
Nahh. I’m pretty good about my cool down lap and not holding the brakes when coming into the paddock.
      10-02-2017, 01:52 PM   #6
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
Something is wrong, I get fairly even wear. Make sure your pistons are working properly
      10-02-2017, 02:31 PM   #7
ZM2
2811
Drives: 2017 LBB M2
Yeah, planning on having the shop clean & lube the pistons on that caliper this/next week. Will find out if it’s resolved in a cpl weeks at Mid Ohio.
m2
