Need advice before buying
09-21-2017, 07:10 PM | #1 |
34
Rep 157
I have a 2011 335i xdrive lowered on koni yellow/eibach setup
Im planning on buying a used set of forgestar f14 Front 19 x 8.5 offset 31 235/35/19 tire Rear 19 x 10 offset 32 265/30/19 tire Will these fit without any issue like rubbing? Do i need fender work? I have no plan on doing any fender work. Do i need a new set of lugs for these wheels?if so, what kind of lugs Please let me know before i pick these up Thanks |
09-21-2017, 08:27 PM | #2 | |
197
Rep 1,070
Ryan at Apex was really helpful too.
JWebb335xi
MHD / Wedge / 93 Octane/ xHP / FMIC / Inlets / Catted DPs / CP / DVs |
10-02-2017, 10:40 PM | #3 |
Rep 43
Not sure about the offsets of my my wheels, but I got same width and height and same tires. I'm lowered on ycw coilovers. And they fit no problems , no fender work. I ordered through **********s. Also they came with bolts that are a little tiny bit longer.
10-05-2017, 06:49 PM | #4 |
19
Rep 64
Could you post pictures?
10-06-2017, 08:37 AM | #5 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
The rears will be a little tight on an LCI car. We have a little wider track and that leaves less room. A fender roll might be needed in the back, front should be good. Front is .8% bigger than the rear too, getting towards the top of what is considered ok.
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
