09-18-2017, 10:50 PM | #1 |
100
Rep 260
Brake Pad Wear indicator
My car tells me my brakes have 3200 miles left. They were checked at the dealer and have 6mm at front and 8mm at rear.
Is the wear indicator that accurate? Seems like a dubious number, does the dealer put that 3200 miles left in my iDrive or is the car that smart? |
09-18-2017, 11:12 PM | #2 | |
1399
Rep 5,262
Dealer might even reset the counter according to how much real pad you have left The sensor will actually trigger when the disc starts contacting with the sensor and then it will show say 500 miles left Anything before it goes yellow is just some estimation |
09-19-2017, 12:02 AM | #3 | |
100
Rep 260
I used to do the pads (and drums) on my older cars myself. Do you know if it's just as straight forward on the 2er? Could it void the warranty if I DIY? |
09-19-2017, 07:59 AM | #4 |
1165
Rep 1,931
this car is very easy to change pads.
The caliper has 2 small pins you need to knock out from front to back, once out, there is a metal clip on top that holds pads in. once you take the top clip off, use your screw driver to open caliper and pop pads out, put new ones in, put clip back ontop, put 2 pins back in.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
Anthony235715.00 |
09-19-2017, 11:29 AM | #5 | |
100
Rep 260
thanks |
09-19-2017, 11:36 AM | #6 |
1165
Rep 1,931
brake pads? nah man...
www.nybmwcca.org
09-20-2017, 01:53 PM | #7 | |
715
Rep 1,541
Don't take the cap off (don't want contaminants getting in). Just loosen all the way. Don't forget to tighten when done!
BM235iW97.00 |
09-20-2017, 02:47 PM | #8 |
3074
Rep 5,577
anyone use this http://www.racingbrake.com/product-p/ccp01.htm
or instead of a C-clamp a dedicated tool to push back piston when doing pads ? |
09-21-2017, 11:17 AM | #9 | |
313
Rep 525
^ I always used a punch to push the pins out and grab it with pliers on other cars.
Also, if you never triggered the sensor, does this mean you can re-use the sensor when you replace the "not-worn-enough-to-trigger" pads with brand new pads? |
09-21-2017, 02:46 PM | #10 | |
1399
Rep 5,262
That's what they said a while back.... i had about 2000mls left and then it started showing 15000... I guess you could but, I think they recommend to replace it with every pad change.... you can get aftermarket sensors for $10 or so... |
09-21-2017, 03:29 PM | #11 |
3833
Rep 2,869
You may want to pull some brake fluid out if there isn't much room above the fill line (at least watch it after each set of pads to be sure you aren't overflowing) - haven't done brakes on a BMW, but in the past it would sometimes overfill the reservoir, spill out in engine compartment where it is impossible to clean fully, and then eats away paint. My buddy had a trick metal 'turkey baster' for this - DK if it will dissolve regular plastic ones.
09-21-2017, 04:04 PM | #12 |
1165
Rep 1,931
Yes you can reuse the sensor.
I buy mine from FCP euro so when they do break, I get free replacements. After you do your brakes, you have to reset your service conditions. Can do this through the dashboard, or buy using a device like bavtech tool. Steps are available on youtube.
www.nybmwcca.org
09-22-2017, 09:41 AM | #13 | |
313
Rep 525
Good to know, but yeah I'll probably replace the sensors through FCP Euro. Still need to check them out, actually, but I digress.
However, if you're at a point where there's too much fluid, you might as well just bleed out some old fluid. |
Maynard3833.00 |
09-22-2017, 06:42 PM | #14 | |
444
Rep 1,262
11-20-2017, 03:50 PM | #16 |
715
Rep 1,541
If I remember correctly the wear sensor is only on 2 calipers, correct? 1 in the front and 1 in the rear.
Pretty sure I noticed this when swapping out my track/street pads.
bryan_G011164.50 |
11-20-2017, 03:53 PM | #17 |
1165
Rep 1,931
two sensors only.
And if it breaks and you don't have a new one available, you can twist the 2 wires together to form a loop, that will take the CEL off the dash until you replace.
www.nybmwcca.org
Anthony235715.00 BM235iW97.00 |
12-18-2017, 12:17 PM | #18 | ||
4516
Rep 8,942
Yours may have been a similar situation.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
12-20-2017, 06:32 PM | #19 | |
340
Rep 1,184
I ended up won't everything I could and then dumping a bunch of denatured alcohol down the same area. |
05-14-2018, 07:46 AM | #20 | |
NewFinishColumbia/detailer
604
Rep 2,096
PM me your info. I will send them to you for free. They are just taking up space on a shelf in my garage.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project http://www.instagram.com/steve_inf31 |
cxp213313.00 mrfattbill25.00 |
05-14-2018, 12:50 PM | #21 |
604
Rep 2,096
I'm down to 1 front sensor.
cxp213313.00 |
