BMW 5-Series (G30) Forum Mechanical Maintenance - Break-in, Oil, Fluids, Servicing Oil level above maximum
      09-16-2017, 09:34 AM   #1
Dantheman90
Dantheman90's Avatar
8
Drives: White 520d G30
I have had my G30 520D for about 5 months now and It has randomly come up with this message about the oil level has increased, I have never added oil to this new car so this seems very odd, has anybody else come across this issue?
      09-16-2017, 04:59 PM   #2
morellomax
119
Drives: 2022 M440i xDrive convertible
Have you done lots of short journeys ? If the car is injecting extra fuel for active regen of the DPF, and some of that fuel is dropping into the sump, it will make the oil level rise.
KeelTiii110.50
      09-16-2017, 05:01 PM   #3
morellomax
119
p.s. (i) this is a potentially very bad thing (ii) I'm not an expert, it's just that this happened to me on a previous car and I'm not sure how else the oil level could rise on its own in an otherwise perfectly working new-ish diesel engine.
      09-18-2017, 07:29 AM   #4
Dantheman90
8
This is what I was thinking, I can think of no reason as to why my oil level would rise on its own.
I have got it booked back in with the dealership but his will not be until the end of next month, I have been very active with this vehicle, around 6200 miles in 5-6 months.
      09-18-2017, 07:50 AM   #5
HighlandPete
6659
Drives: BMW F11 535i Touring
If the oil level is definitely rising, it has to be dilution, not good news at all.
Have you physically measured on the dipstick? I would and if high, try and get the appointment brought forward. At least monitor the oil level on the dipstick.
      09-19-2017, 03:27 PM   #6
Dantheman90
8
The vehicle doesn't come with a dipstick it is all electronically monitored, I plan on calling the dealership as soon as to try and get an earlier appointment, but an issue like this would be covered by the manufacturers guarantee so I am not too stressed, maybe get a new vehicle
      09-19-2017, 05:05 PM   #7
HighlandPete
6659
You also have a physical dipstick in the G30 with the B47 engine, it is at the rear of the engine. (Illustrated on the sump assembly and the dipstick is part number 11438513859).
      09-19-2017, 06:39 PM   #8
Dantheman90
8
Thanks! I will lift the cover and have a look at this later on today
      09-20-2017, 04:19 AM   #9
morellomax
119
You have to get up very early to catch Pete out
      09-20-2018, 06:24 AM   #10
ADS-UK
ADS-UK's Avatar
United Kingdom
499
Drives: G30 - 530d M Sport
I know this is an old thread. I had the same issue and BMW Assist decided to come to pick up the vehicle which was surprising. I now got the car back from the dealer who says it was a faulty reading from the sensor. They've re-coded the car. I'm a bit sceptical about the explanation as I had to ask them few times to get a response.
Dantheman90 What did they tell you?
      09-24-2018, 06:33 AM   #11
AndrewUK
AndrewUK's Avatar
United Kingdom
22
Drives: 530D xDrive G31Touring M Sport
I have a G31 530d Touring, and this same issue has arisen with my car - it has been in to BMW (Blue Bell, Crewe) and they have told me that they can't find any problems. Driving my car back from the dealership, the warning flashed on the screen again. Not impressed.
      09-25-2018, 01:29 AM   #12
ADS-UK
ADS-UK's Avatar
United Kingdom
499
I'm looking for a proper explanation as well. I called BMW Assist when it happened and they offered to come and pick up the car. It also felt like something they are used to. But my dealer was just like yours. Didn't give me anything until I probed them.
      09-25-2018, 02:33 AM   #13
AndrewUK
AndrewUK's Avatar
United Kingdom
22
My car has gone back to BMW - what explanation did you receive after you "probed" them??
      09-25-2018, 03:55 AM   #14
ADS-UK
ADS-UK's Avatar
United Kingdom
499
They said it was a faulty reading from the sensor. I asked them if they replaced the sensor. They haven't as they think it's more to do with the reading/software. So they've ended up updating the software to latest version (S15A-17-11-520). I haven't had any issues since then but it's only been few days.
I'm keen to hear what they tell you.
      09-25-2018, 04:00 AM   #15
AndrewUK
AndrewUK's Avatar
United Kingdom
22
I'll let you know - thanks for the update!
(I thought the system software updated itself automatically such that you always had the most up to date version anyway?? Obviously not....!)
      09-25-2018, 05:42 AM   #16
ADS-UK
ADS-UK's Avatar
United Kingdom
499
No. It's only the maps that update automatically. Even that's not as timely as you'd like them to be.
      09-26-2018, 05:22 AM   #17
AndrewUK
AndrewUK's Avatar
United Kingdom
22
BMW have advised me that they will be changing the oil and updating the system software - they have no explanation as to why this issue has arisen, but they tell me that "these actions normally get rid of the problem". Based on their comments, clearly this is something that happens a lot.
      09-26-2018, 07:42 AM   #18
ADS-UK
ADS-UK's Avatar
United Kingdom
499
So pretty much the same what I've been told.
      09-26-2018, 10:32 AM   #19
AndrewUK
AndrewUK's Avatar
United Kingdom
22
Yes - but still no real explanation of the underlying issue.
      12-06-2018, 05:33 PM   #20
zaidld
Drives: G30 530D M Sport
I had the same issue. BMW changed the oil and reprogramed the car. Oil level this time was between min and max. I returned to the dealer the next day for explanation. They said that that the instructions they had from Germany is to put half litre less than the usual. Since then I have being monitoring my oil levels. For a couple of weeks it's has been on half way between min and max. Then started going up to two thirds and now it's on max. I have taken the car back twice to BMW but they keep saying there is nothing wrong with my oil levels!
      01-02-2019, 08:54 AM   #21
JohnEnglish
288
Drives: Black
I mentioned it in the other thread but a bunch of new Audis are having the same issue. Audi issued a TSB and dealers are replacing faulty units with new ones under warranty.
5post
