Rear side window seal on E92
09-14-2017, 01:01 PM | #1 |
55
Rep 266
I have a 2007 E92 coupe and I need to replace the rubber seal surrounding the rear wide windows. I checked RealOEM and the diagram does not show the rubber seal as a separate item.
Does anyone know if the window comes with the rubber seal attached? In other words, I would need to buy the window as well, instead of just buying the seal?
2007 335i E92 FBO | MHD Stage 2+ 93 octane | xHP Stage 3 | Fuel-It! Stage 2 LPFP | VRSF 7" FMIC | VRSF Catless Downpipes | ER Chargepipe | HKS SSQV4 BOV | Ultimate Racing CAI
09-15-2017, 08:20 AM | #3 |
149
Rep 460
I just googled it and yes it looks like it's available. ECS Tuning as well as others carry it. The front rubber seal was shot on our 2007 335i. It was not a bad job to replace it. Just be careful around your paint and glass when you pry out the old seal.
09-15-2017, 08:48 AM | #4 |
55
Rep 266
I believe that is for the front and rear windshields. I am referring to the rear side windows on a coupe. The 2 small windows on the sides. The rubber molding for those, I can't find them. RealOEM shows those 2 windows without the rubber seal being a separate item. Thus why I believe the seal is part of the window itself. If someone can confirm this, that would be great, though that would suck if I had to buy a new window just to replace the seal.
