Dension 500s BT factory phone?
09-12-2017, 08:55 AM | #1 |
Rep 18
Hi all,
Hope someone can help me I've got a 2007 BMW E91 with no bluetooth but the phone cradle installed in my center armrest I'm now installing the Dension 500s BT and would like to use it for handsfree now their guide mentions I need to take the phone modul out of the MOST loop however I'm not sure where I'd find this module can someone assist? Thanks a lot in advance! |
09-12-2017, 10:42 AM | #2 |
1911
Rep 13,104
http://www.e90post.com/forums/attach...2&d=1260829447
I think its page 36 or somewhere near the end that shows the location of the TCU in the trunk. But you shouldn't have to remove anything to my understanding especially if you don't have Bluetooth installed. http://www.e90post.com/forums/showthread.php?t=657749 Dension 500 http://www.e90post.com/forums/showth...hlight=dension http://www.e90post.com/forums/showth...hlight=dension http://www.e90post.com/forums/showth...hlight=dension http://www.e90post.com/forums/showth...hlight=dension http://www.e90post.com/forums/showth...hlight=dension There is also an install video or two on ytube. |
09-13-2017, 03:00 AM | #3 |
Rep 18
Thanks a lot for your help turns out I do have factory bluetooth but the "mulf" is broken it's actually interfering with the tension when plugged in I'm getting an additional MOST loop connector today so I can bypass the MULF and use all of the functions of the Dension.
I'll put an update here once it works. Thanks for the help! |
09-13-2017, 09:18 AM | #4 |
Rep 18
All good now removed the MULF from the MOST loop and now have factory bluetooth running via the Dension no additional coding required again thanks a lot for your help!
