09-12-2017, 07:08 AM | #1 |
Cheapskate
4450
Rep 4,993
Reverse Default To Top View
When I put my car in reverse, iDrive defaults to the rearview camera. Is there a way to make the default camera in reverse be Top View/Surround View (with or without coding)?
Things that don't work: 1. Pushing the iDrive controller/camera button doesn't flip between rear camera and top view cameras. I have to go to the left, scroll down, and uncheck the box "Rearview Camera" every time. 2. Say I uncheck the box and reverse into a parking spot but don't like my alignment. If i inch forward and then go back in reverse for a 2nd try, it goes right back to the rearview camera <--- especially annoying when someone is waiting behind you. 3. (6MT Only) Park with shifter still in reverse and turn off the car. When I start the car with the shifter still in reverse, it shows the top view camera still. But if i go into neutral and back to reverse, it reverts to the rear camera. I have a 2018 f32, but it seems like some 2017s may experience the same setup from the factory. Discussion started in this thread: http://f30.bimmerpost.com/forums/sho...php?p=22182196 |
09-15-2017, 11:33 AM | #2 |
Cheapskate
4450
Rep 4,993
bump
09-15-2017, 08:23 PM | #4 |
Cheapskate
4450
Rep 4,993
there's no way to adjust the native coding? or look up which firmware I have?
09-15-2017, 08:26 PM | #5 | |
2374
Rep 8,364
You can easily check firmware with E-sys, but I have no idea which ones support. My F010 does; my F015 used to before last update. |
11-29-2017, 07:59 AM | #6 |
81
Rep 80
Anyone have an update on this?
2018 BMW 440i Coupe, High-Exec, MPPSK, HUD, Dig dash, touch-nav
2014 BMW 335, High-Exec, MPPK, MPE, HUD 2011 Audi A5 2009 Alfa 159 2005 Alfa 156 |
11-29-2017, 08:38 AM | #7 |
Cheapskate
4450
Rep 4,993
A BMW Genius confirmed that the reverse camera became standard on LCI models because of US regulations that require reverse cameras on all new vehicles after 2018. With the changes to meet NHTSA requirements came a programming change to default the reverse camera view. I'm not sure how that affects other regions.
I have started selecting the PDC button when i'm in a parking lot or getting ready to park and i just scroll over to hover on the reverse checkbox. When I go into reverse i can quickly press the idrive controller to switch to top view cameras. It's a hassle but a lot better than sitting in the middle of the street while fumbling through menus. |
01-08-2018, 09:21 AM | #8 |
303
Rep 481
OMG- I'm so annoy my 2017 340i defaults to rear-camera view in reverse EVERY SINGLE time.
Has anyone discovered coding to fix this?!? I want surround view on alllll the time....
2023 G05 Phytonic Blue/Cognac, M Sport, Prem Pkg, Parking Assistance Pkg, 22", M-sport red brakes, heated armrests, 4zone climate, HK, extended shadowline
01-09-2018, 07:55 AM | #10 |
Cheapskate
4450
Rep 4,993
This only works when pressing the PDC button or approaching an obstruction from the front. Like when I'm pulling into a parking spot forwards or into my garage, it starts up in the last used view (top view). But if you shift into reverse, it automatically defaults to the rear camera.
01-09-2018, 12:37 PM | #11 | |
13
Rep 67
01-10-2018, 07:29 AM | #12 |
Cheapskate
4450
Rep 4,993
Are you located in the US? If you could find the setting it would be GREATLY appreciated.
Even if I shift into reverse and manually turn off the rear camera so that the top view cameras are shown, when i shift to 1st and back to reverse (without moving anywhere) it automatically changes back to the rear view camera. No matter what it won't stay in top view. |
07-08-2019, 03:03 PM | #17 |
1890
Rep 3,877
I've complained about that in another thread as well. Also Europe here. Defaults to reverse. I got used to it in the meantime, but would love an option to default to Surround view.
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
kern4174449.50 |
02-23-2020, 08:23 PM | #19 |
Cheapskate
4450
Rep 4,993
Nope, unfortunately. Works perfectly on my 2010 X5, and it has top view cameras. It was definitely something that they changed and locked for the newer safety regulations.
02-24-2020, 11:32 AM | #20 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
This change was implemented around 2016, if your car is 2016+ or if your i-step level was updated after 2016 then you probably lost this feature.
02-24-2020, 10:28 PM | #22 |
1890
Rep 3,877
First of all - it is called surround view just for the record.
Second - pushing the P console button does indeed activate surround view on all model-years. The problem is when you put the gearbox in reverse. That's when newer models default to rear-view camera. Very strange that your 2018 doesn't... 🤨 European or American?
