Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Cosmetic and Lighting Modifications (exterior/interior) > help installing HPB 240W AEs
      09-10-2017, 03:00 PM   #1
geko29
1565
Drives: 2023 M3 6MT
I just spent the better part of an hour failing to get the driver's side unit installed on my 335d. I don't think the light unit itself would be a problem. But the sheer size of the two outboard units and the weatherpack connector are a major issue. I simply cannot jam them into the housing anywhere, and still have enough room for the stock halogen bulb, much less the far larger LED module. The only thing that seems like might work is to forget about the weatherproof cap, and leave all the extra detritus hanging into the engine bay. That doesn't seem like the greatest idea.
Anybody installed these already and have some tips?
      09-13-2017, 09:15 AM   #2
Jaronbwall
Driving cars and riding bikes really fast
Jaronbwall's Avatar
Drives: 2009 335i
These are the LEDs from Top Gear Solutions that have the mini cooling fans correct? I was about to purchase those tomorrow so I'm questioning the fitment now.
335i, sport pkg, 3 pedals, Blacked out, LED markers, OZ Ultraleggera wheels, Firestone Indy 500s, x-pipe, vibrant 1792, PE mod
MHD stage 2+, BMS DPs, ARM charge pipe, Tial BOV, ARM FMIC, dual cone, CSF radiator, M3 control arms, sways, HAWK pads.
https://www.strava.com/athletes/8309149 Follow me on Strava
      09-13-2017, 09:17 AM   #3
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
They fit fine just like any other offering. Just takes some patience and fiddling to sort out what goes in first and where.
I usually dip the back end (fan side) of the light in first. Then put the LED inside the orifice. After that I just lay anything else in the compartment. We've installed dozens locally without a hitch and sold 100's.
      09-15-2017, 12:12 PM   #4
Jaronbwall
Jaronbwall's Avatar
Drives: 2009 335i
Thanks a lot man! Look forward to getting mine.
      09-16-2017, 08:17 PM   #5
cpie168
173
Drives: 2010 E90 328i 6MT ZSP BSM
Just installed the HPB 240W H8 angel eyes on my E90 LCI last night. Very happy with the outcome. The light is very bright and the distribution of light is perfectly even. The inner rings are super bright but the outer ones are dimmer, but that's to be expected due to the design of the E90 angel eyes optics so that is due to no fault of HPB.
However, the installation took me over 1.5 hours because I had such a hard time screwing the bulbs into the sockets. For the driver side, I had to remove the intake airbox but it still took me a very long time after that. For some reason it took a great deal of effort to turn the bulb to lock it in place. The design of the bulb with the square heatsink didn't allow much torque to be applied when turning it in such confined space. It was just a nightmare and I still can't believe I was able to get them in. So consider yourself warned if you're going to embark on this!
Anyway, like I said above, the outcome is great so I quickly forgot about the pain of installation soon afterwards. I was also able to cramp the multiple outboard units into the headlight housing and shut the cap properly without issues. It's a tight fit but definitely doable.
Unless LUX offers easier installation, I can't see how the HPB 240W can be beat for the money. I paid only $99 for the HPB bulbs as they were on sale (and still is at the time of this posting).
Appreciate 2
      09-18-2017, 03:54 PM   #6
For someone installing angel eyes for the first time, it's never as easy as it should be, as the concept is as easy as changing a light bulb, right? Haha
Once you become proficient and do it a few times it should take no more then 15 minutes for E92's who install at the top of the light. For all other vehicles that require access through the fender liner, there is a little more set up time.
It's best to note the orientation the stock bulb came out, then remember that for the new bulbs, that will make lining up the 3 tabs a lot easier.
Small hands is a plus!
      09-19-2017, 04:37 AM   #7
geko29
1565
Drives: 2023 M3 6MT
Does this mean you put the two components on the wire in through the hole after the light is installed (and then put the cap on), or that you lay them out in the engine compartment and leave the cap off?
      09-19-2017, 07:07 AM   #8
Jaronbwall
Jaronbwall's Avatar
Drives: 2009 335i
I would think the cap goes back on to protect everything from moisture and dust.
      09-19-2017, 04:38 PM   #9
Everything goes inside the compartment and leave the cap on.
      10-03-2017, 06:43 AM   #10
arhoads335i
180
Drives: 2015 435i grand coupe xdrive
2008 BMW 128I  [0.00]
Could OP post a picture at night? not sure if I want these or to crack open my e92 lights and put rings in.
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current)
2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD)
08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD)
      10-03-2017, 06:54 AM   #11
mfractal
VAG Survivor
mfractal's Avatar
40
Drives: E90 335i
Not op and not in the night but I got this pic of them.
Left side is 240w, left is ebay cheap led
F10 535i LCI, Hybrid Turbo, Custom Inlet, Spool FX-150 Pump HPFP, TI Automotive LPFP, DV+, Phoenix IC, FTP CP, High Flow Cat, M5 Mufflers, Custom Tuned By David Shoup.
      10-03-2017, 07:09 AM   #12
cpie168
173
Keep in mind the E92 will look different from E90. The outer rings of the E90 don’t light up very well not because of the bulbs but due to the poor design of the light pipes inside.
      10-03-2017, 08:02 AM   #13
BeastMode335i
Maximus Decimus Meridius
BeastMode335i's Avatar
Drives: F30 335i
Takes a bit of finesse but I got mine in after about 10-15 minutes..
F30 335i
Melbourne Red Metallic
M-Sport Package
      10-03-2017, 09:16 AM   #14
No need to crack open the lights there is accessible panels at the top of the E92. It takes about 10 seconds or less to open the panel.
Yea that's how long it usually takes me now, if that.
      11-06-2018, 06:57 PM   #15
kittytower
Drives: 2009 328xi
Sorry to resurrect an old thread.. I'm currently trying to install these and have them lined up but can't seem to turn the bulb to lock it into place. They are supposed to turn and lock, right?
      11-06-2018, 09:35 PM   #16
cpie168
173
Yes it should lock, but from what I remember, it barely does.
      11-06-2018, 09:57 PM   #17
kittytower
Drives: 2009 328xi
It doesn't turn at all for me. Do you mean it barely turns or barely locks? Feels like it could fall out from a nice bump.
      11-07-2018, 06:50 PM   #18
Etek
41
Drives: 2020 M340i xdrive
It should lock with a light twist. I had the same problem when I first tried to install. It was an orientation problem where the tabs didn't line up. Once you get it lined right it should lock no problem. The only tip I can give you is out the original bulb in and take it back out and line up the led bulb same way
      11-09-2018, 12:14 PM   #19
Just make sure the orientation is correct. Not the factory bulb orientation of the tabs. Mimic that with HPB 240W H8 Angel Eyes.
It's about a 1/8-1/4 turn when it locks in. It will feel secure. Anything short of that is not installed correct - change the orientation.
      11-10-2018, 02:01 PM   #20
kittytower
Drives: 2009 328xi
I think it's correct, the tabs and holes look like a T and they slide in when turned the right way, but it doesn't twist in either direction afterwards. It is much bigger than the OEM one which makes it hard. I actually have the headlight off of the car and still can't get it...
      11-18-2018, 02:26 PM   #21
Etek
41
Was wondering if you got the lights to install securely. If not maybe include pics
      12-03-2018, 06:46 PM   #22
kittytower
Drives: 2009 328xi
I got one side and haven't since touched them, just too busy, but will update once the other side is in. I guess you just have to push harder, it's a little bit scary but then it clicks in and stays. No idea how one could do this with the headlights still on the car....
Also it is indeed difficult to fit the harness inside, but it fits and the lid does shut. I'll post a pic later of how I fit it. If anyone reading this is struggling, just walk away from it for a few and try again, it is possible.
