Front door storegae compartment
09-10-2017, 11:09 AM | #1 |
Rep 98
Hi All,
After searching the net high and low, I'm hoping someone has some tips on how I can remove the retractable storage compartment, on the front door panel picture below. Thanks in advance |
09-10-2017, 06:26 PM | #2 |
203
Rep 739
just guessing, no idea otherwise, are there any bolts/screws/etc in side that panel anywhere? or maybe look on the inner area where the door panel meets the body of the car? And there might be a "screw" inside that open area to the left of the panel as well. Or maybe even check underneath that panel. again, just guessing...sorry.
09-11-2017, 02:12 AM | #3 |
34
Rep 210
Try this... http://workshop-manuals.com/bmw/3_se...n_door_pocket/
Lots of painters tape (could of layers going into the crack as well) around the door panel surrounding the pocket door so when you insert a pry tool (nylon or plastic bone tool recommended) you do not damage the door panel. I used a couple of these types of tools to slowly try it up / off evenly. Now, I was only removing and replacing the damaged door cover in my instance so I did not try and remove the whole pocket door assembly... Last edited by Speed_Addict; 09-11-2017 at 02:18 AM.. |
09-11-2017, 03:57 AM | #4 | |
Rep 98
This is what i needed, thanks for taking the time to post and reply with the details. |
