Missing brake wear sensors (brake + 4x4) light HELP PLEASE
09-10-2017, 10:49 AM | #1 |
13
Rep 38
Sorry if this has been addressed
I recently purchased a 06 330xi. The car runs great, brakes work great but there was a red "brake" light on dash. As well as 4x4! I was changing headlights when i noticed the front driverside brake wear sensor was just dangling there. I went to closest autostore and bought one. Got home changed it with a breeze and went to other side to see its completely gone. So I checked the rear and same thing, completely non existent. After I changed the one I reset the fault code through carly and on dash. The RED light turned to YELLOW. Im changing the rest this weekend but out of curiousity which I can not find in any of my searches I am lead here to ask: Can this lead to the 4x4! Light being on, or can I assume its completely seperate issue and look further into the issue? I have no ABS light on, no fault codes on dash other then yellow brake light and cc-id 351 and 354 My bluetooth is non existent as well as my cruise control being disabled. Any help would be greatly appreciated. Last edited by Acornell77; 09-10-2017 at 10:56 AM.. |
09-10-2017, 12:07 PM | #3 |
90
Rep 386
Drives: 08 535xi 11 328xi
You should only have a sensor on the left front and right rear for the brake pads. For the 4x4 light, that might be for the steering angle sensor. Try calibrating by turning the wheel all the way in both directions, this should clear the light.
Jb4/MHd BEF, XHD Stage 3
DCI, FTP Charge Pipe |
09-10-2017, 01:07 PM | #4 |
13
Rep 38
First off thank you both for the replies. Just saved me $40 and the work involved.
That makes sense. I was a little upset to see them missing. Ive tried to collaborate the steering wheel angle sensor but no luck. Hoping to try smaller things I can DIY because that angle sensor seems extensive and not something I would want to do myself. So if all brakes are ok and sensors are ok, why would I still have a yellow light on dash after reset and codes cleared? Not sure if its worth mentioning my battery is running 14.2 running and holding 11.7 after sitting the night I had to reset airbag/seatbelt codes and register battery |
09-10-2017, 06:57 PM | #5 |
13
Rep 38
So I decided to try to calibrate the steering wheel sensor one last time. Well this time it worked, but only for about 5 minutes.
I was super happy thinking I was all set pulled in my driveway and it turned back on. My assumption is the angle sensor needs to be replaced but if any of you have any input on this that would be greatly appreciated EDIT UPDATE: I can duplicate the problem. I can get lights too turn off and stay off for as long as im driving, the moment I come to a hill to stop is when the lights turn back on. I kmow there is assisted start with braking system but not sure what can be causing this. Im documenting this so if anyone else might have similar problems. This is NOT tge trifecta brake,abs,4x4 issue. Last edited by Acornell77; 09-11-2017 at 06:36 AM.. |
12-14-2019, 04:37 PM | #6 | |
Rep 4
12-15-2019, 10:16 AM | #7 |
2440
Rep 4,330
probably not without a way to talk canbus with the car.
which if you're having similar issues I would highly recommend you sort out with a kdcan adapter and INPA/ISTA/Protool |
