If anyone is considering spacers...
09-05-2017, 11:52 AM | #1 |
203
Rep 739
I just put 15mm/12mm (rear/front) on my 2009 e93 with OEM 193 rims. The car is not lowered etc, fully stock suspension. I can tell you so far, (a) they ride perfectly fine and (b) they are about at flush with the fenders as you can get. i have no idea how people are putting 20mm spacers on the rear with no rubbing, at least without fender rolling. I had my installer really scrub away all the rust and gunk from the hub before installing the spacers with anti-seize.
Love the look! FWIW, mine are from burger. And yes, came with the longer bolts. |
09-05-2017, 02:35 PM | #4 | |
395
Rep 662
We need some pics!
I've been thinking of adding some spacers & studs at all four corners. I've pretty much settled on 12.5mm front, but still debating whether I should go 15mm or 17.5mm rear. I'm guessing you think I should go with 15mm. My 330i has sport suspension, and will stay on the staggered OEM 162 style wheels w/stock size tires. Since you have experienced the 15mm, would the extra 2.5mm be just enough to be "too much" for the above setup?
09-05-2017, 02:56 PM | #5 |
203
Rep 739
I knew i would be asked for pics here are a few (assuming they work, quite often the forum says my pics are too large, not sure how to resize). As for going higher than 15mm, on my stock 193 w/8.5 wide rears, I think they'd stick out too far. As it is, it's close.
[ok, tried to upload, forum says they're too big...no idea why!] |
09-05-2017, 04:29 PM | #10 |
178
Rep 267
Looks pretty great! Lovin' those first two picture from the rear, the car looks so much meaner when you can see most of the back of the tire.
09-05-2017, 04:38 PM | #11 |
203
Rep 739
Thanks, I love it. on the other hand, and maybe it's normal, or just me, or something else, but it "appears" the camber is off? if that's the right term. Kinda looks like the tire is a bit towed in towards the top v. the bottom. I hate to even mention it in the event someone tells me there's something wrong!!!! But the spacer is flush with the hub and the wheel is flush with the spacer...
09-05-2017, 10:27 PM | #12 | |
68
Rep 298
Drives: '16 330e
Toe in (or out) is the same concept but looking from the top down. You'd have to check the alignment specs, but if I recall the front wheels have a slight toe in, and the rear wheels are less or mostly parallel. Anyway, the spacers look great, if there was a problem you'd probably notice it as a vibration. I need to up my spacer game, haha - running stock sport suspension (rwd) with staggered stock sport wheels. There is room for improvement on mine. |
09-06-2017, 08:04 AM | #14 |
12
Rep 52
I am thinking about probably 20mm spacers for my fronts. It is a 08 E91 touring and I recently bought these M3 rims for dirt cheap and refinished them.
The rear is about perfect IMO with the wider tires on it. The front I think need about a inch or a touch less spacers though.....thoughts? ETA: suspension and everything else is all stock everything.
09-06-2017, 11:03 AM | #17 |
111
Rep 529
I am lowered on the Bilstein B12 prokit with the staggered wheel setup (18X8 and 18X8.5 OEM wheels). I tried spacers to get a flush look - 12 front / 15 rear. The 15 mm in the rear caused rubbing. Uninstalled until I can get my fenders rolled.
2011 335d Deep Sea Blue on Beige (stock except for the cheap ass wheels from PO)
2010 328i Tasman Green on Saddle (stock) |
09-06-2017, 12:17 PM | #18 | ||
395
Rep 662
15mm on the rear looks *perfect* Thanks for sharing the info & pics!
09-06-2017, 06:49 PM | #20 | |
37
Rep 131
Drives: 2018 MPE BMW 440i xDrive
Garage List 2018 BMW F32 440i x ... [0.00]
2008 BMW E92 335i [0.00] 2014 BMW F32 435i x ... [0.00] 2016 BMW F33 428i [0.00] 2006 BMW E90 330xi [0.00] |
Insta: @zenshorts
2018 Valencia Orange (MPE) BMW 440i xDrive |
09-06-2017, 07:14 PM | #22 |
12
Rep 99
Drives: 2012 335i coupes
I just installed 20mm rear and 12mm front. 20s rub pretty good. I have 15 mms on the way lol
