Bmw problem warninglight meana
09-04-2017, 11:20 PM | #1 |
Rep 33
Hey i just got my bmw today and near the odometer im having a yellow triangle with numbers 303 beside it , any1 knows what it is please
09-05-2017, 12:11 AM | #2 |
Apprentice
373
Rep 801
I'll bite. A picture would help. The 303 you're seeing is probably the trip meter reading. It has nothing to do with the yellow triangle. Hit the button on the dash and you'll see that number reset down to 0.
The yellow triangle could be plenty of things. If you have a screen you could check it there (not sure how to navigate because I don't have a screen in my car, someone could chime in on that). If you don't have a screen then there is a stalk on the left hand of the steering wheel that has the letters "BC" on it. There is a little knob where you could push up and down on it. Push down until you see "Check Control" on the small screen of your dash. Push the BC button and there is where you will see the error icon. |
09-05-2017, 02:59 AM | #3 |
Rep 33
Ye the numbers are the meters you was right , as when i press the BC button i see check then press on it and says check ok only, but tbh sometimes it comes like a bulb woth an exclamation mark in it , i think maybe a bulb could be ?
09-05-2017, 08:25 AM | #4 |
Apprentice
373
Rep 801
A bulb with an exclamation point means you have a light bulb out somewhere.
