Tirerack
Use the following links to go directly to useful tirerack winter items: Tirerack Winter Tires. Gary's Winter Tire FAQ.
Using the links directly supports E90Post with tirerack sales commision!
The Tire Rack
   PLEASE HELP SUPPORT E90POST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS!
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Will this set-up work?
Please help to directly support e90post by doing your tirerack shopping from the above link. For every sale made through the link, e90post gets sponsor support to keep the site alive. Disclaimer
      05-14-2008, 10:51 AM   #1
ricolaw
7
Drives: 335xi
OK I've asked a few people on this board their opinion on whether this set-up will work on my e92 335xi and wanted to know if anyone had any additional input. I'm getting a set of iForged size 20x8.5 and 20x10 and plan on running toyo t1r's size 245/30/20 in the front and 285/25/20 in the rear and dropping it with H&R sport springs. Will this rub? I would prefer NOT to roll the fenders or any other modifications, however, aftering talking to some of you I'm under the impression that I still may have some rubbing in the rear, especially with 2 people in the back. Anyone have any experience with this issue? Thanks!
      05-14-2008, 10:57 AM   #2
BMW F22
BMW F22's Avatar
Drives: ///M235i
What's the offset on them? With the correct offset it should work. However, I would go with 275 instead of 285 as there is more inherent risk of rubbing with 285.
      05-14-2008, 11:04 AM   #3
ricolaw
7
Drives: 335xi
Not sure of the offset Kenny. I would assume iForged would make the correct offset as they are made specifically for my car, but who knows. Anyways, isn't a 275 tire going to be stretched?
      05-14-2008, 11:25 AM   #4
BMW F22
BMW F22's Avatar
Drives: ///M235i
275 is fine on 10" wheels. 265 is perfectly fine with 9.5" so since you're only going up by .5", 275 will work just fine. The only thing is that it's virtually impossible to find 275/25/20 tires. So your only choice would be to go with 285 but that might require fender rolling. When putting in the order make sure you let them know what you're planning to do so that they can take everything into consideration.
      05-14-2008, 06:10 PM   #5
ricolaw
7
Drives: 335xi
I guess I'll just have to see what happens.. the xi sits slightly higher to begin with and the h&r sport drop isn't too extreme so I'm hoping I'll be OK. Anyone else have any input?
