Real FIX for the auto folding mirror not stopping where it should
08-28-2017, 09:42 PM | #1 |
Cuba
81
Rep 1,676
I have been having this problem for a few months now and refused to get a replacement mirror. Found this solution posted on another site and decided to try it out before getting a mirror replacement.
I tried many many times to pull the mirror in all the way, click the mirror button, and click it again and it folding back into place. This never worked for me. Solution: 1. Remove mirror cap 2. Drill a small hole down through the first layer with a 1/4" drill 3. You'll know you drilled far enough when you see the exposed hole. 4. The small hole is already exposed so you do not drill this hole. 5. Spray some WD40 into the hole and use a small allen wrench or a 1/16" drill bit to stick in there and push with some force (nothing will happen but will loosen the pin a bit) 6. Bring your mirrors all the way in 7. Click the mirror button and as the mirror is folding out push down into that hole with your small allen wrench or 1/16" bit. (basically you are manually pushing the pin down instead of relying on the spring) At this point you can spray some WD40 or lithium grease in the hole to hopefully loosen the pin. Or snip the white wire to remove the folding function to this mirror, and eliminate the chance of this happening again.
07 328xi Monaco Blue|Premium|Cold|Navi|CA|LLumar|Mtec|DDM|aFe|Ambe r-Gone|Rear Fogs|Bimmian|PY-Speed|OEM|e92-lighting|V1|BavAuto|Weisslicht|Cyba|Beyern|Falken| Sonic Tuning|ECS Tuning|JL Audio|Rockford Fosgate
08-29-2017, 08:29 AM | #2 | |
2341
Rep 3,539
Thanks man, hopefully this ends this damn issue once and for all. How did you get this solution? I mean how did you know to drill that hole there? |
08-29-2017, 08:31 AM | #3 |
Cuba
81
Rep 1,676
Someone had posted about it on a other website. forget the link, I'll try to find it and update the credit
08-29-2017, 04:36 PM | #5 |
armchair enthusiast
221
Rep 1,019
I've only folded my mirrors a handful of times in 8 years, and they missed half the time. I just don't fold them. :/
'18 340i xDrive EB/Dakota, 6-speed manual, M-sport
'02 325Cic vert AW/Montana leather, 5-speed manual, premium/removable hardtop '93 850Ci Oxford Green/Parchment, auto '71 Buick Riviera, 455 V8 land yacht |
08-29-2017, 05:05 PM | #6 |
324
Rep 2,014
Is this an issue with pre-LCIs only?
WedgePerformance E40 MHD | Performance Exhaust Mod | BMS DP | Vibrant 1790 | BMS Intake | VRSF CP | xHP Stage 3 Michelin PSS | M3 Control Arms LUX v4 LEDs | Shadowline Grills | Lip Spoiler |
08-29-2017, 06:45 PM | #7 | |
68
Rep 298
Drives: '16 330e
It's posted in the DIY on here, but the single-post poster has posted on several sites according to google. |
08-29-2017, 08:21 PM | #8 |
1007
Rep 2,108
That is not the real fix! This is the real deal fix!
http://www.e90post.com/forums/showth...7#post21716397 Seriously though, if you don't have access to a welder, there is nothing wrong trying to fix by drilling into. |
08-29-2017, 08:24 PM | #9 | ||
Cuba
81
Rep 1,676
