2010 335i msport: Bilstein B4 shocks/struts as good as OEM?
08-28-2017, 02:54 PM | #1 |
51
Rep 147
Hi guys,
I am having the factory shocks and struts replaced on my car which has approximately 80k miles. What's the best shock/struts for the price utilizing the OEM sport spring? ECS Tuning sell a very affordable Bilstein B4 OEM replacement set. Should these be just as good as the factory shocks? https://www.ecstuning.com/b-bilstein...t/22-135049kt/ Also, what other parts should be replaced? The shop I spoke with recommends replacing the upper front strut mounts and upper/lower rear shock mounts for the rear. Is there anything else that should be replaced on the strut assembly? Thanks! |
08-28-2017, 03:58 PM | #2 |
743
Rep 1,096
Drives: '01 Z3M, '12 335is, '22 540i
Garage List 2012 BMW 335i [5.25]
2012 BMW 335is [5.00] 2008 Infiniti QX56 [0.00] 1967 Chevrolet Corv ... [10.00] 2001 M Roadster [10.00] 2022 BMW 540i [0.75] 2009 528i [9.50] |
I had a set of B4's put on my 323it two years ago. I did need some parts replaced in the rear (upper mounts I believe) plus two new stock springs, but didn't need anything else up front, other than the new struts. Car had just over 200k miles at the time, and the shocks were original. My opinion? -- the B4s are better than stock, at least for these stock springs on a daily driver.
08-28-2017, 04:29 PM | #3 |
They don't want you to drive a 335i - DJ Khaled
126
Rep 444
B4s are great. I did a refresh on my 335i with 80 on the clock. Its a whole new feeling. Ride significantly better but no increase in roughness. It might be a tad stiffer but in a good way. I used to lose traction on bumpy roads and roads with imperfections. Now its drive much better, smoother and sportier.
For me - handling, traction and ride quality for sure improved for sure. Road noise and high speed stability is better as well - could be a placebo effect as its not everyday I hit 130+. |
Habimmer0.00 |
08-28-2017, 04:59 PM | #4 | ||
51
Rep 147
08-28-2017, 06:43 PM | #5 |
72
Rep 613
i got those installed last year with 110K on my ride, but with H&R sport springs. i wish i went with factory springs cause it dropped my car too much. i scrape every where and have to drive at crazy angles to avoid scraping. looks good though, but just a bit too low for me. smh.
N54Society448.50 |
08-28-2017, 11:09 PM | #6 | |
1903
Rep 6,968
Drives: 2007 Black/Black 335i e90
N54Society448.50 |
08-29-2017, 02:41 AM | #7 |
30
Rep 158
I would recommend replacing the bump stops as well. Someone correct me if I'm wrong, but at 80K miles they are likely worn or going to be soon. If I remember correctly(this might be 1 series info, but should even then they have the same suspension design) at stock ride height the car actually rides on the bump stops. BMW even calls them auxiliary shock absorbers.
08-29-2017, 06:27 AM | #8 | |
ahat
1036
Rep 2,592
B8 is lowered I think
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
08-29-2017, 07:52 AM | #9 | |
1903
Rep 6,968
A b12 kit would be better than the m-sport to be sure |
08-29-2017, 09:21 AM | #10 |
193
Rep 666
B4s with the sport part number is equivalent to the OEM M-sport shocks.
The B6s and B8s have the same exact valving inside; but the internal bump stop is set differently for stock spring height vs lowering springs.
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
08-29-2017, 10:15 AM | #11 | |
126
Rep 444
B4/B4 Sport for OEM replacement. B4 for non sport suspension, B4 Sport for M sport suspension. B6/B8 and so on are all upgrades. B6 is a bit stiffer and sportier than B4 B8 is b6 with shorter shaft to be mated with lowering springs (mostly aesthetics) b12 is stiffer and lower than B8 to be mated with performance lowering springs. So on and so forth Having replaced with B4, I can tell you that this is an ever so slight upgrade from OEM but OEM replacement nonetheless. Id highly recommend changing out all the shock mounting components. Makes a huge difference. |
08-29-2017, 10:25 AM | #12 | |
181
Rep 657
B8 is the correct replacement for MSport suspension. |
lab_rat394.50 |
08-29-2017, 12:32 PM | #14 |
Rep 52
08-29-2017, 12:37 PM | #15 | |
Grandmaster
768
Rep 798
B6 and B8 are performance upgrades, not an equivalent damper to what came on the car from the factory. The B4 is intended to be the equivalent replacement for OE dampers. However, if you wanted a performance upgrade for m-sport vehicles, you are correct in saying that you would use the B8.
Daily - 2018 Alpinweiß ///M2 6MT Exec Rain/Snow/Winter - 2011 328i 6MT Sedan - Black on Black, Sport Package Sold, But Not Forgotten - 2009 135i 6MT - Black on Black, M-sport, JB4 |
08-29-2017, 02:20 PM | #16 | |
181
Rep 657
Where do you get your info from? |
08-29-2017, 02:42 PM | #17 | |
Grandmaster
768
Rep 798
It's hard to argue which one is supposed to be the OE replacement with the statements "Bilstein B4 OE Replacement restores original ride characteristics". and "Bilstein B6; better than the original"
Daily - 2018 Alpinweiß ///M2 6MT Exec Rain/Snow/Winter - 2011 328i 6MT Sedan - Black on Black, Sport Package Sold, But Not Forgotten - 2009 135i 6MT - Black on Black, M-sport, JB4 Last edited by Joebie; 08-29-2017 at 02:51 PM.. |
N54Society448.50 |
08-29-2017, 02:57 PM | #18 | |
181
Rep 657
08-29-2017, 08:12 PM | #19 | ||
1903
Rep 6,968
08-31-2017, 10:51 PM | #20 |
51
Rep 147
thanks for all the feedback guys. Honestly, I am more confused now if the b4 is the OEM equivalent. Page 105 of the application guide lists the b4 for sport suspension on a 2010 335i sedan.
09-01-2017, 07:41 AM | #21 | |
Grandmaster
768
Rep 798
Man, if only it could somehow be made more clear like if they put "OE replacement" in the B4 name or something.
09-01-2017, 07:55 AM | #22 |
1007
Rep 2,108
factory Msport option maybe different than just sport option. You may get better answer at suspension sub forum.
