Help, abused and neglected
08-27-2017, 07:29 AM | #1 |
Rep 25
Picked up a 09 Le Mans blue m-sport. Happy with the overall look but when I look at the car closely it looks like who ever owned it was a pig..:sorry to the previous owner but...every surface inside is scratched or pealing. Any advice?
1 Aluminum trim looks like it's pitting/like someone through a bunch of keys at it, every where! Dash, center console, door trim 2 Black coating is bubbling and pealing on steering wheel and door grab pockets 3 navigation face gas a white milky smear, smooth to the touch and goes away when you wet it but comes right back when dries, short replacing I'm thinking some type of silicone/oil rub? 4 rims are best to shit. Curb rash everywhere 5 black aluminum trim around windows and down sides of roof is pealing from previous overzealous details 6 rubber trim around windshield is cracked all around 7 front plate bracket is on front bumper and looks like shit. I'm in PA so I don't need it but I'm sure there are drilled holes underneath The car is low miles and drives well. Looks great overall but the details are driving me crazy. It's an overwhelming list...any suggestions on how to tackle it? |
08-27-2017, 07:35 AM | #2 |
1858
Rep 2,554
Well it sounds like the damaged components should be replaced. Every new car you acquire used will require some level of TLC. You should?ve saw that upon purchasing it and use those things to bring the value down and as you could argue it?s going to cost you the difference if not more (way more) to replace all those items.
I?d rather a damaged interior than a damaged engine or exterior. Interior can be interchanged easily so look at it as a fun project and after it?s done you?ll feel accomplished and satisfied. Sucks some people don?t treat their stuff with proper care. |
08-27-2017, 07:49 AM | #3 |
Rep 25
That's pretty much what I thought. I thought the price was fair so bought it based on mechanics. Drives well, all seals and gaskets are dry clean car fax and extensive maintenance records so I didn't want to miss out on it. It's getting harder to find low mileage examples...
I'm just overwhelmed with where to start and if I'm doing it or a shop...I generally use the dealer as my previous previous '11 e90 was a cpo with a warranty plus it was immaculate. Truly like new. I'm a little bewildered with where to start. I know I'm not a diy guy so at least I know my limitations...any suggestions are appreciated. |
08-27-2017, 08:35 AM | #4 |
203
Rep 739
I know jack shit about cars personally but I've done quite a bit of simple, non-mechanical, work using youtube Videos. Try searching your specific issues there. If you don't mind spending on the parts, there are a ton of interior trims on eBay. Rims are simple to switch out or refurbish. I have accompany by me that will do the rims for $150 a pop, not awful. And yes, there will be holes in the bumper. You can just get plastic little grommet things from Home Depot and paint them body color and pop them in. I did that with one of my cars. It's not perfect but better than holes. You can rewrap your steering wheel or buy one off eBay as well. The exterior trim might be tricky since windows might need to be removed for removal. Or take it to a body shop and have them painted.
08-27-2017, 08:37 AM | #5 |
203
Rep 739
And I think there are posts somewheee on how to get the nav screen clean. Might be similar to how folks get their yellowed headlamp plastic clear again. Not positive. Good luck!
08-27-2017, 08:58 AM | #6 |
Rep 25
Thank you just feeling a little overwhelmed I guess I'll need to sit down make a list and address them one at a time like everything else the dealer promised to do the wheels for me at their cost so I'm taking them up on it at 75 bucks a pop and then to the body shop to take care of the trim in the from bumper I'll try to tackle the interior on my own
08-27-2017, 09:30 AM | #7 |
17317
Rep 18,739
Sounds like the original owner over-detailed the interior with products that damaged the various materials and surface coverings.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
08-27-2017, 09:35 AM | #8 |
Gateropode
329
Rep 2,848
Looks like somebody used the wrong chemical for cleaning the inside. The rubberized paint and the plastic screens will not like -at all- chorox wipes or something stupid like that and will do exactly what you are describing here.
You will need to repaint/replace the peeling trim. You can buy most pieces from BMW the price is surprisingly not too gouge-y. For the aluminum pieces, I don't know how textured they are (I have wood), but if smooth, you can polish it with the same paint polisher you use on exterior paint. For the screen, rub it with plast-x or some similar abrasive solution for plastic to remove the layer that has been contaminated and whitened. Then seal it with an acrylic based paint sealant with U-V protection (Klasse high gloss, or something from an headlight restoration kit). Use blue painter tape to limit your operation field. The rubber trim around windows is a wear and tear item. Replace, there's a DIY, it's a 2h job that's not particularly difficult. You can plastidip the window trim, there's also plenty in the DIY section of the forum on how to proceed as that was all the rage a couple of years ago. |
08-27-2017, 11:26 AM | #9 |
2188
Rep 5,002
Start watching you tube trim removal videos. The instructions are out there for everything you mentioned. Buy parts on eBay or here.
Mileage isn't everything, as you're learning. A more holistic approach is required with cars. If you pay the dealer to fix these things you'll be looking at thousands. |
08-27-2017, 01:19 PM | #10 |
30
Rep 162
congrats on the new car purchase but sorry to hear from your interior woes. win some lose some. A lot of people like to get their trims wrapped in a new color so you can tackle the worn out trims by rewrapping it in the same color or a new texture. it is relatively cheap and easy to do, certainly a lot better than replacing the whole interior trim set which can be costly. the steering wheel trim is a cheap item to replace so to wrap or not is onto you in my opinion. I would personally take this as an opportunity to get a new steering wheel which can really freshen up the interior. another fairly easy project to tackle, there are plenty resources on this forum and youtube that will guide the installation and removal process. the one that might be a bit more time consuming is the door pull,card trim. the curb rash can be easily polished out ranging from 50-100 a piece depending on people around your area. craigslist or yelp is a good place to start, quote around! hope this helps, enjoy your new beast
08-27-2017, 01:41 PM | #11 |
185
Rep 1,017
Start looking int either replacing the interior parts,wrapping,or painting. These cars are hitting the yards, so parts will be available. It's about how much your want to put into it. Just start a little at a time.
08-27-2017, 04:12 PM | #12 | |
Rep 25
08-27-2017, 07:28 PM | #14 | |
2188
Rep 5,002
https://www.realoem.com/bmw/enUS/select Try to stick with OEM whenever possible. For all the trim on the interior I don't think you'll find anything except OEM. You'll get it, just save the numbers in a spreadsheet so you can reference them easily while you're working. There are several online retailers that will also have what you're looking for new. The aluminum trim you're definitely best off i'm on craigslist eBay or the forums. That stuff is a complete rip off new You can definitely replace the stuff yourself. Interior parts removal is really pretty easy and it's all built well enough that it will go back together with ease. A lot of the aftermarket speakers suppliers have online DIY's for everything. Look up BSW speaker installs |
Efthreeoh17316.50 |
08-27-2017, 09:02 PM | #15 | |
Rep 25
08-29-2017, 07:50 PM | #16 |
2188
Rep 5,002
