08-26-2017, 03:58 PM | #1 |
32
Rep 53
225 Square Set-Up
I see a lot of talk here about the 245 square set-up ,but I am thinking about doing a 225 square set up.
My car is a 2014 M235i with staggered OEM tires/wheels. I've tracked it a couple of times, and am getting frustrated with how fast the tires wear out, especially the outside fronts. I have run OEM PSS and A/S 3+. i understand neither are optimum track tires and the best move would be dedicated track tires with camber plates. My car is a daily driver that gets taken to the track probably 4 times a year. I consider myself a novice driver, skill-wise, with much to learn. I have an HPDE class coming up in Sep, and I'd like to put fresh tires on for that event (the event is a 600 mile round-trip road trip from my house). I'm leaning toward springing for a set of rims to mount these tires on. I'm sold on a set of 4 18x8 rims with 40 mm offset, but trying to figure out the rubber. I'm really impressed by the price of the Hankook Ventus V12 Evo2s (a max performance tire). Quite a bit cheeper than the Michelins I have been running, and they are offered with a 100 rebate right now. Out the door on a square set (225 all around) would be about $100/tire. In my mind, I think that is pretty good bang for the buck. It goes up another $100 if I put 225 on front and 245 on rear. Is the extra 20mm of rubber on the back worth the $100 extra? I have also started researching extreme performance tires, and the Fallen Azenis RT615K+ has caught my eye. Tire Rack has them for $130/tire. If I thought they would cream the Hankook's on the track performance-wise, and still be safe to drive on the street day in and day out, I would probably spring for a 225 square set of them as my summer tires. So big questions: 1. 225 square vs 225/245 staggered? Big deal/difference on the track? 2. Max performance vs extreme performance. Which would you pick for daily drive, occasional on the track? Keep in mind, I'll keep a set of A/S 3+ on another set of rims for cold wx driving. Thanks in advance. |
08-26-2017, 09:03 PM | #2 |
1165
Rep 1,931
you can run 225 with spacers, would be poking out just like a 245 but with less rubber on the road.
you would benefit more from a brake upgrade TBH, pads and fluid flush, lines. Wreck the tires you have, than you can purchase something that will work on track and off. If you are buying dedicated track tires and wheels, go with 17's... Lighter, tires are cheaper, and even if you decide to drop the car, you wont rub.
www.nybmwcca.org
Current Cars: 1995 M3 Coupe Manual Alpine White 1997 M3 Sedan Auto Cosmo Black Metallic 2018 x3 m40 Auto Grey Metallic |
08-27-2017, 11:05 AM | #3 | |
32
Rep 53
Why would you use spacers? With the right offset, shouldn't I be able to achieve the same effect. I'm looking at Einkei Raijins, 18x8 with a 42 ET. My math tells me they will sit further out than the OEM setup. I'll drive the extremes to and from the track, and use the A/S 3+ for DD. The A/S 3+ really is all I think you need for street use, but they have no place on a track. Can I expect the Extreme tires to hold up much better on the track or just perform better? BTW, what 17 inch wheels do you recommend for a 245 square set up? Last edited by skitch; 08-27-2017 at 07:30 PM.. |
08-27-2017, 08:21 PM | #4 |
1165
Rep 1,931
i have those wheels, what questions do you have?
You can run a 235 tire upfront and rear if you wanted without spacers.
www.nybmwcca.org
08-27-2017, 09:27 PM | #5 | |
32
Rep 53
I'm beginning to lean toward a 17x8 245/40/17 square set up. Trying to find a 17x8 wheel that will work on the M235i w/o spacers. Rubber I like right now is the Hankook RS4. My car is completely stock. Looking for any wheel suggestions that will definitely work. Prefer to order through Tire Rack or Discount Tire. Thanks. |
08-28-2017, 04:50 PM | #6 | |
20
Rep 77
08-28-2017, 09:05 PM | #7 | |
32
Rep 53
Thanks for the help. |
rich8566608.50 |
08-29-2017, 10:10 AM | #8 | |
1165
Rep 1,931
www.nybmwcca.org
08-30-2017, 09:12 AM | #9 |
228
Rep 301
08-30-2017, 10:40 PM | #10 |
32
Rep 53
I just got done installing my set tonight. I ordered through Tire Rack and got the Hankook RS-4 245/40-R17 mounted on TR Motorsport C4 17x8 ET 40 wheels. No spacers. Car is bone stock. So far, so good. Gap between tire and strut is about the same as OEM.
ChrisFulton227.50 |
09-05-2017, 08:51 PM | #11 | ||||
609
Rep 1,124
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
09-08-2017, 06:17 PM | #12 |
228
Rep 301
Thanks for this info!
09-10-2017, 03:21 PM | #13 |
32
Rep 53
Just got done doing an HPDE at Pueblo Motorsports Park in Pueblo, CO. Drove from ABQ, NM to Pueblo and back, plus four 20 minute sessions on the track. Very impressed with the performance and lack of wear. i'll try to do a full review soon.
09-10-2017, 07:02 PM | #14 |
228
Rep 301
Skitch, are you running stock springs?
09-21-2017, 11:33 AM | #16 |
313
Rep 525
Would you mind getting a pic of your wheel/tire set up from the front and rear so I can see how they sit with respect to the body of the car?
Also, any track day videos? |
09-24-2017, 06:52 PM | #17 | |
32
Rep 53
http://www.2addicts.com/forums/showthread.php?t=1421450 Didn't gat any track day video footage. |
