08-22-2017, 06:57 AM | #1 |
14
Rep 75
2013 F30 320D ED + BimmerCode
I know there is a large thread in the main forum but i want to see how people over here in the UK got on with the app and Vgate iCar 2 adapter
Also i have a F30 2013 320D ED has anyone made changes/coded to one of these as i want to see what the main changes can be made before i buy the adapter required as id hate to have little changes to make after buying Appreciated in advance guys |
08-22-2017, 09:51 AM | #2 | |
978
Rep 2,069
Once connected, the app reads all relevant modules & lists what can be changed. Select what you want, click on "code" button & move on to the next. It really is that easy.
/// BM3 + M-Power ///
BimmerStrutt14.00 |
09-01-2017, 01:33 PM | #3 | |
14
Rep 75
ECU read and not the biggest list of options but a few i wanted so not all bad I tunr from NOT ACTIVE to ACTIVE and press CODE i then get met with in-app purchases spinning indicator and nothing? is the £24.99 a must purchase before you can change anything? From what i read it seemed like it wasn't unless you wanted to code loads of cars? Also when i do get this working and done i must be able to remove the adaptor once ive pressed disconnect? Little stumped
09-05-2017, 04:27 PM | #4 | ||
978
Rep 2,069
09-06-2017, 03:38 AM | #6 | |
14
Rep 75
Thanks for the confirmation, must admit the Vgate Icar 2 adapter is a cool bit of kit, for some reason i thought it would be bigger than it is but ist very small and compact
