M2 Technical Topics > Track / Autocross / Dragstrip > Rear Alignment
      08-21-2017, 08:34 AM   #1
ZM2
2811
Drives: 2017 LBB M2
Rear Alignment
Hey guys.
The focus is always on the front, and it seems folks are gravitating to -2.75 with 0 toe after some testing on the track.
Just curious where you all are ending up with your rear alignment? I've gone as far as -2.2, but it seemed too much based on treadwear and loose rear traction coming off the corner. I've gone back to -2.0 and it helped, but I still wonder if less would be better.
Also, I've stayed consistent with 0.3" toe in the rear based on my shop's recommendation, but no one seems to have a good idea what rear toe should be.
Obviously the tires you run will have an impact on this (RE-71R and R888R for me), but what have been you all's experiences?
Thanks.
      08-21-2017, 02:08 PM   #2
tstafford
tstafford's Avatar
30
Drives: 2017 M2
I'm at -2.2 in the rear and liking it.
      01-25-2018, 05:43 PM   #3
look585
look585's Avatar
311
Drives: M2CS
2020 BMW M2 CS  [10.00]
I always run toe in on the rears.
As you pick up speed and up to speed, the toe in will start toeing out. Even at speed you want a little toe in.
      01-25-2018, 06:00 PM   #4
ZM2
2811
Drives: 2017 LBB M2
I ended up at -2.0 and 0.3”. Wear looks good and is very stable with good grip.
m2
