335i 2A15 Fine leakage detected
08-19-2017, 10:48 AM | #1 |
96
Rep 346
I'm currently getting a 2A15 DMTL Fine leakage code (tighten gas cap). I replaced the gas cap but it still comes back after 50-80 miles. I've read that the DMTL pump hose rubs with the AC hose and erodes which causes this code or the DMTL simply has gone bad. Anyone know where this hose is located so I can inspect it before buying a new pump?
08-30-2017, 07:13 PM | #2 | |
68
Rep 298
Drives: '16 330e
My car will throw the gas cap icon, and I get a Service Engine Soon light. I get 2A15 and 2A16 using INPA. There was a post about the vent hose from the tank to the front, rubbing on the chassis near the rear tire. It looked like an involved fix to replace the entire tube. Does your gas tank kick off early when filling? Mine does frequently, so that's leading me toward pressure imbalances or a fuel tank vent issue. I'm trying to diagnose this without blindly replacing things. |
08-31-2017, 11:25 PM | #3 | |
96
Rep 346
Yeah I think it does kick off early sometimes... and i have read that post about the fuel tank hose next to the wheel I still haven't checked it out but I will this weekend and see what happens
09-01-2017, 08:22 PM | #4 |
3821
Rep 4,660
Drives: BMW
If you don't see any damage to any hoses, it's likely the actual DMTL module connected to the carbon canister in the rear. 2A15/2A16 faults may make it look like there is an actual leak somewhere but in my case, it was a false reading. I replaced the module as a last effort type of thing before finally just tolerating the CEL but after replacing it, never got that fault again. Fortunately for you, it's not the most expensive part, maybe a couple hundred.
09-02-2017, 09:54 AM | #5 | |
68
Rep 298
Drives: '16 330e
My INPA setup isn't working 100% when it comes to testing stuff in the DME, so it won't let me run the DMTL tests. But your experience does give me some hope that I just replace it and be done with it. Those hose connectors are a pain to remove! |
09-03-2017, 12:42 PM | #6 | |
3821
Rep 4,660
Drives: BMW
