F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > BMW 330e exhaust
ARMA SPEED
      08-15-2017, 05:04 PM   #1
leholtet
11
Drives: BMW 123d
BMW 330e exhaust
Anybody tried to fit 335i/340i exhaust to this?
      08-15-2017, 07:27 PM   #2
D041987
Big Turbo Boys N Girls
D041987's Avatar
Drives: 2012 328I 6speed
Would be the same as any other exhaust. Should bolt right up with cutting at the dimple.
      08-16-2017, 08:21 AM   #3
Domotron
Domotron's Avatar
Drives: 2014 BMW 328xi M-Sport
yeah it should fit without any issue
      08-16-2017, 09:37 AM   #4
Eikka
Drives: 330e
I always thought the 330e uses a bespoke muffler because of the battery pack...would love to have a meatier exhaust note on mine though. Subscribed...
Edit: pic from google
http://throttlechannel.com/wp-conten...nel.com-13.jpg
      09-03-2017, 01:16 PM   #5
Alan_Tan
Malaysia
18
Drives: BMW F30 330E
i custom a quad valvetronic exhaust system on my 330e
      07-30-2018, 01:18 AM   #6
vivisterist
Drives: bmw f30
How’d you get a valvetronic system to work with this? Which one did you use ?
      06-08-2019, 06:13 AM   #7
JaiR
Drives: 2018 BMW 318i (LCI)
How did you get quads? Doesn't the battery pack block it?
      06-08-2019, 07:51 AM   #8
hybris
hybris's Avatar
Norway
205
Drives: BMW 330e F30 M-sport
Modifying the original exhaust is probably your best bet. Depending on much sound you want you can remove or replace the rear muffler, and replace the downpipe with a high flow cat or decat. The tailpipes you can replace with whatever you fancy and thinks look good.
This route is typically cheaper than buying something aftermarket as well, and almost nothing aftermarket is confirmed to fit the 330e, so you risk having to modify it anyway.
Thorbjorn
16 BMW F30 330e M-sport
Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs
      10-20-2019, 10:02 AM   #9
mia_chem
Norway
12
Drives: f30 2016 330e
Any update on how to modify the original exhaust? I'm looking to have something like the dual single tip exhaust like 335/340i's have
      10-20-2019, 10:37 AM   #10
hybris
hybris's Avatar
Norway
205
Most exhaust shops will be able to help you out with a custom exhaust, but having tips on both sides will require some additional modification (and possibly to your bumper too). I went with dual on just one side (same as original) but with a bigger diameter (2x3"). 2x80mm (3.15") will fit too, but I didn't find one I liked.
Thorbjorn
      10-21-2019, 08:27 AM   #11
mia_chem
Norway
12
I have the sportline bumpers so I'm considering getting a new m sport rear bumper + diffuser anyways. Also the closest exhaust shop is 9+ hours away so i'm trying to find something that I can do myself. Do you have pics of your setup?
      10-21-2019, 11:04 AM   #12
hybris
hybris's Avatar
Norway
205
So, here's a bunch of pics. Before/after removing mid-muffler, before/after replacing rear muffler (note that the tail pipes on this pic is not the ones I ended up with, which are slightly bigger). And downpipe (haven't got a pic of that on the car). The final two pictures (in box and on the car) show the tailpipe I currently have. Pretty similar looking than the one in the closeup, but slanted and a bit bigger (3")
Thorbjorn
      10-21-2019, 02:51 PM   #13
mia_chem
Norway
12
That looks really good, but its the symmetric aesthetic im looking for so I'm not sure if i'd go for something like that. How's the sound after removing the mid muffler?
      10-22-2019, 01:16 AM   #14
hybris
hybris's Avatar
Norway
205
Removing the mid muffler had little effect, perhaps slightly deeper sound and a slight drone when the engine meets resistance at medium RPMs (say going up a hill). If I were to do it again I probably would have left it there. Replacing the rear muffler and replacing the downpipe had the most significant impact on the sound.
The rear muffler is now a Magnaflow 11376 that has a nice deep sound, reasonably quiet on idle/cruise, and pretty loud on WOT. The downpipe increased the sound an additional 50% or so, but no additional drone and still pretty quiet during cruising. (It's a catted 200cel downpipe, not catless)
Thorbjorn
      12-15-2019, 02:37 AM   #15
Zamgu
Zamgu's Avatar
7
Drives: F30 335i
Here is my custom exhaust setup. 3" straight pipe controlled by the valve, otherwise there is Magnaflow muffler. Exhaust tips are 100mm
Appreciate 2
hybris204.50
      12-15-2019, 03:20 AM   #16
hybris
hybris's Avatar
Norway
205
Nice. So the valve controls whether it goes through the left or right pipe? Should be pretty loud even when it goes through the muffler? Any drone?
Thorbjorn
      12-15-2019, 03:51 AM   #17
Zamgu
Zamgu's Avatar
7
Drives: F30 335i
Only the left pipe is straight piped when the valve is open, else the flow goes through the muffler to both pipes. Yes, it is pretty loud with very deep sound. Sound is perfect on the front seat but at the back seat there is little drone.
      12-19-2019, 05:02 AM   #18
kristianl330e
Denmark
15
Drives: BMW 330e
2020 BMW 330e  [0.00]
2016 BMW 330e  [0.00]
No issues with the lampda, fault codes and so on with the downpipe?
      12-19-2019, 05:29 AM   #19
hybris
hybris's Avatar
Norway
205
To ensure no fault codes, you need a tune. I have BM3, so the fault code is supressed.
That being said, I ran with the downpipe without a tune for two months without any fault codes - but most downpipes will throw a code eventually.
Thorbjorn
      12-19-2019, 05:47 AM   #20
kristianl330e
Denmark
15
Drives: BMW 330e
Ok, sounds good.
I run a custom map so that could be an issue for me. Unless i have it remapped again.
I heard that the fault code could be avoided if you use a spacer on the lampda to move it away a bit.
The BM3 suppresses all fault codes, right? That could be a bit dangerous.
      12-19-2019, 05:50 AM   #21
hybris
hybris's Avatar
Norway
205
Ok, sounds good.
Yes, a spacer works sometimes. The downpipe I have from RM Motors has a built-in spacer (a pipe extending from the actual downpipe).
BM3 only suppress/deactivate the catalytic efficiency sensor, and only if you specifically activate that feature. It does not suppress anything else.
Thorbjorn
      12-19-2019, 05:56 AM   #22
kristianl330e
Denmark
15
Drives: BMW 330e
Ah, okay.
That sounds good.
What kind of power are you making now?
f30post
