08-14-2017, 08:28 AM | #1 |
M240i-MW
13
Rep 12
CG Precision Ds-1 5" catted downpipe
Hi,
https://www.cgprecision.com/#!/DS-1-...egory=17975141 Would this downpipe fit an M240i? Seeing as most downpipes made for B58 fit all x40i models. Was hoping if people would think this downpipe would fit? Seems they have only tested on 340i's so they haven't listed it to fit other x40i's. Heard this downpipe on a few 340is and they seem to sound good through videos. A lot less rasps/tinny in comparison to all catless downpipes for b58 Thanks, would be good to hear what you guys think |
08-14-2017, 09:04 AM | #2 |
716
Rep 912
Drives: '17 F22,15 E84 M Sport,02 R53
Everything I have read / seen says that a downpipe that fits the 340i will fit the 240i.
08-15-2017, 06:56 AM | #3 |
M240i-MW
13
Rep 12
08-15-2017, 08:59 AM | #4 |
716
Rep 912
I'd love to have a lower restriction catted DP as well, however I am not willing to deal with CEL's. While the lower restriction DP does free up the motor, I got a Dinantronics Elite and it really woke up the car - so I am ok with that for now.
08-16-2017, 01:43 PM | #5 |
243
Rep 447
From what I'm reading/understanding is the 240i's have a computer limit to the amount of power that can be added. It appears even basic piggyback tunes sometimes bump up on this hard limit AA8 tune is example, and thus adding a downpipe or using E85 isn't really a benefit as you'll hit that limit. Until a flash tune is out, or some kind of work around for piggybacks to get around the hard limit, other than better sound, a downpipe seems not so desirable when matched with a tune.
Please correct me if I'm wrong, as it wouldn't be the first time.
'15 M235xi | BSM/Oyster/Aluminum | Black Kidneys | RW Carbon Mirror Caps | 40% tint
08-16-2017, 04:30 PM | #6 |
Joint Chiefs of Staff
24060
Rep 190,575
Should fit
08-17-2017, 10:36 AM | #7 | |
813
Rep 553
08-17-2017, 10:42 AM | #8 | |
716
Rep 912
The B58 engine which is in the M240i and the 340, 440, 540, 640, 740 etc does have a fueling cap in the ECU. This means that the once certain parameters are hit the engine will pull timing and adjust fueling to limit the power. This is hard coded into the ECU - until someone cracks it, it is the limiting factor unless you get a JB4 and methanol injection.
12-31-2017, 07:54 AM | #10 |
2924
Rep 1,303
Drives: 2021 C8 Corvette 1LT
I have this sport cat downpipe installed. Fits much better than the VM catless DP. Granted, I think my vm catless was manufactured wrong and it wouldn't seal entirely at the turbo (had carbon deposit all on the top of the gasket and DP when I removed it). Exhaust is a little quieter, but still screams at WOT.
12-31-2017, 01:09 PM | #11 |
807
Rep 1,368
Upper 300's at the wheels without meth. If I had to guess, I'd say I'm around 370 whp SAE with JB4 Map 3 on 93 octane and BMS intake (stock DP). Hoping for around 410 with 50/50 meth/water (Boost Juice).
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ Pure 800 cast/ DS2/ E40 Doug Newton tuned/ ER catless DP/ Remus axle back/ BMS intake/ FTP CP/ M Performance LSD
Tags |
340i, b58, cg precision, down pipe, m240i exhaust |
