BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > H&R lowerings springs
      03-01-2006, 02:17 PM   #1
lumbergh
lumbergh's Avatar
Drives: BMW 325i
I have a non sport package. Will the H&R springs bring it a little closer to the SP ride height and feel.
I'm thinking of going with 19's also. From what I've seen it's looks like this combo would be OK or similar to SP with 19's. Any advice otherwise??
Does anyone know of a good shop to do the install of the springs in Houston,TX?
Thanks
      03-01-2006, 02:28 PM   #2
HRC
MAUI BUILT
HRC's Avatar
Drives: 2006 330i MT
2002 E46 325i  [0.00]
2012 E70 35i  [0.00]
No idea on shops in your area.
The H&R sports will drop you past the ZSP height. The ZSP drops you about .6 from non sports. The sports will drop you 1.3 or whatever it is from stock non-sports height.
Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
      03-02-2006, 09:32 AM   #3
lumbergh
lumbergh's Avatar
Drives: BMW 325i
Thanks, I think that will be about right regarding the height.
I called a local shop and they wanted $370 for the springs and $400 for the install.
I figured they would mark up the springs quite a bit so I didn't really plan on buying the springs from the shop but $400 for the install seemed kind of high too from what I've heard in other cities.
Does anyone know what a fair price is for the install. I swear I saw someone getting them installed for around $350 including the cost of the springs, but that was in LA and I'm in Houston.
Thanks for the help.
      03-02-2006, 11:30 AM   #4
shragon
Moderator
shragon's Avatar
497
Drives: BMW
that's quite a bit.
you should be able to get the springs for $250-300.
in the bay area, the install would probably run $200-300, and we have really high labor rates in california.
i'd shop around.
      03-02-2006, 11:34 AM   #5
kekoa
14
Drives: 06 e90
I would not pay more than $150 for a spring install. I know its tougher than doinga Honda, but anything over that is rape.
      03-02-2006, 12:34 PM   #6
HRC
MAUI BUILT
HRC's Avatar
2012 E70 35i  [0.00]
Regarding install price, it really is apples and oranges. It depends almost entirely the area in which you live. Here in California, you can get installs as cheap as $100 - $150 in LA. In Northern Cali, totally different story. I've been quoted from $330 including alignment to $450 not incuding alignment. :mad: I'm still looking!
Danny
      03-02-2006, 01:11 PM   #7
lumbergh
lumbergh's Avatar
Drives: BMW 325i
Geography must make a difference. Houston is a big city with a lot of sport tuned cars so I would think there would be several places to get this done, I'm just having a hard time locating competent shops that do this. I've done several internet searches and I'm not coming up with much. I guess I'll have to keep asking around.
If I could get this done for $500 total I would be happy.
Should any mechanic shop be able to do this?
      03-02-2006, 02:40 PM   #8
HRC
MAUI BUILT
HRC's Avatar
2012 E70 35i  [0.00]
Originally Posted by lumbergh
...Should any mechanic shop be able to do this?
I wouldn't let any shop work on my car. The shop must be expereinced with euro cars for me to consider. Man, it's like finding a babysitter! Well, not that tough, but not easy for me!!
Danny
      03-02-2006, 04:53 PM   #9
creativeautoworks
Drives: Ibis White 2007 Audi A4 S-Line
Drive over to us
      03-03-2006, 01:11 PM   #10
lumbergh
lumbergh's Avatar
Drives: BMW 325i
Originally Posted by creativeautoworks
Drive over to us
A drive to San Diego from TX would be a nice break. Only if I had the time.
Does anyone have any advice on changing the shocks when changing the springs? Is it necessary? It seems like it would be a good time to do it but I'd rather not if I didn't have to.
Thanks
      03-03-2006, 01:22 PM   #11
HRC
MAUI BUILT
HRC's Avatar
2012 E70 35i  [0.00]
...Does anyone have any advice on changing the shocks when changing the springs? Is it necessary? It seems like it would be a good time to do it but I'd rather not if I didn't have to.
Thanks
You don't have to swap out the with the installation of lowering springs. But really, if you don't, the dampers will wear out faster and you will not get a tight ride as you do when you have a matched set. I was about to install the springs alone until I found out the Koni's are available right now.
If you have the zsp package, it's not that big of a deal because the zsp dampers are already calibrated for a lower rideheight compared to the non zsp. But even if you drop it with the H&R Sports or Pro-Kits, it's still .6 or so lower than the damper was designed to operate.
If you can, I recommend buying dampers to go with the springs. This way, you pay for install only once, since the dampers come out for spring install anyways, and you will have a much better ride.
Danny
