Which tire setup works better? Or recomendations.
05-08-2008, 04:48 PM | #1 |
Rep 150
I'm looking at getting rims 19's... front are 8.5 and back are 9.5 ET 35.
The setup i'm looking at is. falken fk452 235/35/19 275/30/19 or 235/35/19 265/30/19 Any other thoughts or suggestions? Will this work without having problems with the abs sensor, ect ect. |
05-09-2008, 12:58 AM | #4 |
749
Rep 2,108
just to clarify why i said first one its because i have a friend with that setup and he hasnt had problems, but sometimes they say measurements differs from one brand of tires to the other.
there is another thread about the exact same thing your asking about, it might be helpful here u go http://www.e90post.com/forums/showthread.php?t=140437 |
05-09-2008, 01:02 AM | #5 |
The Law.
301
Rep 14,283
Bigger does not always mean better. Unless you have traction issues i'd go with 235/265 setup.
And no you will not have any issues with sensors as long as you transfer your OEM TPMS to your new rims. |
05-09-2008, 01:19 AM | #6 | |
195
Rep 2,816
If you are sure 235/275 will work without rubbing...then fine. I am running 245/275 on my setup. And I don't rub unless i fully load the car and go fast over a dip in the road. I like the 245/275 for the added rim protection. But if it's going to possibly rub...then going with 235/265 is good... |
05-09-2008, 12:23 PM | #9 |
Now With 33% MORE Sarcasm Free!
157
Rep 3,462
235/265 and couldn't be happier... Although the Continentals are sized slightly narrower than the Goodyear GS-D3s were so I don't have quite the same "stuffed" fenders look I had before.
Just don't go cheap with the tires, remember that a narrower tire can also reduce noise, tram lining, will weigh a little less, and increase fuel mileage. So as others have mentioned wider doesn't mean better. There is a reason BMW equips the E92s with the tire package it does and it's not just economics, the OEM tire sizes are all that is "needed" for reasonable street performance/longevity/ride comfort.
A BMW is Just a Car, it doesn't make you smart, handsome, clever, better, cool, or wealthy. |
05-09-2008, 07:19 PM | #10 |
156
Rep 10,411
235 and 265
Why would you want more understeer in the car?
2010 AW e90 328i: 6 speed, Black Leather, Dark Wood trim, ZPP, ZCW, ZVP,ZSP, Nav, Xenon
BMW Performance CF Rear spolier and Gloss black grills 2008 Candy White MKV GTI 2.0T 6 Speed Manul Gone 2008 AW X3 3.0si: 6 speed Returned 2006 AW e90 330i: 6 speed Dinan Stage 1 Returned |
