Do you "warm up" your E90 before driving off?
07-19-2017, 06:33 PM | #1 |
Crazy Frog
543
Rep 1,212
Just a curious young lad wondering if other E90 owners do this....or am I just weird/paranoid?
I live in NYC & Buffalo (for college). Here is my fighter jet start up sequence. Hot/warm weather start up sequence: 1) Get in the car 2) Key into the slot, turn ignition on but not start it 3) Wait 5 seconds for fuel pump and other electronics to "initialize" 4) Foot on brake and start the car. 5) Let idle for exactly 30 seconds, to let oil circulate throughout the engine. 6) I put on my seatbelt, turn on A/C or music in this time 7) Put into drive and take off. Cold weather sequence: 1) Get in the car 2) Key into the slot, turn ignition on but not start it 3) Wait 5 seconds for fuel pump and other electronics to "initialize" 4) Foot on brake and start the car. 5) Let idle for exactly 60 seconds or until RPMs drop below 900. 6) I put on my seatbelt, turn on heat or music in this time 7) Put into drive and take off. I know I might sound crazy, but I just "feel better" doing this lol. If it was a rental car, I wouldn't give a s**T. Does anyone else do this? |
07-19-2017, 06:34 PM | #2 |
Apprentice
373
Rep 801
For the cold weather, I do the exact same thing. I feel like letting the engine drop the RPMs has given it enough time to get the juices flowing. I also try to keep it no higher than 3k RPMs until I see the oil starting to warm up on the dash.
07-19-2017, 06:40 PM | #3 |
1552
Rep 3,475
Drives: E90 6MT FBO; '18 F150 Platinum
thats some paranoid shit man
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+ BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq. 2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast |
TheProphet11.00 |
07-19-2017, 06:47 PM | #5 | |
Cometh
1090
Rep 1,308
Drives: Boy's Soul
07-19-2017, 07:44 PM | #8 |
293
Rep 644
Drives: 2018 6mt AW m2
I personally feel like it's a good idea to let it warm up for a minute or two. Let the oil pressure rise, etc. But I guess I'm just paranoid.
07-19-2017, 07:49 PM | #9 |
293
Rep 644
My friend Adam killed the turbo on my Eclipse GST by running the hell out of it and then not letting it spool down with oil pressure by just shutting it off! This was when I was car ignorant. After that, my next 2 turbo cars both had turbo timers. I learnt my lesson after that but modern turbo cars are unaffected by this so its ok. Reading your post brought back alot of forgotten memories
07-19-2017, 07:56 PM | #10 |
317
Rep 1,735
07-19-2017, 07:56 PM | #11 |
39
Rep 151
Drives: 2010 e92 335i AWD
07-19-2017, 08:32 PM | #12 |
551
Rep 2,293
I just let the rpm settle and go . Usually i try my best to keep it below 3500 rpm for 5-10 minutes
But i m not really paranoid about it , sometimes I go over 3500 rpm , sometimes I dont have time to let the rpm settle. |
07-19-2017, 08:44 PM | #13 |
86
Rep 639
I just drive off in any weather but I keep it under 3k rpm until the oil is at operating temperature. I give the turbo time to cool down only after pushing the car hard. Even though it's water cooled it still needs to cool down and you need to have the coolant passing through to cool it down. Just idling an engine will allow oil flow but it is a very inefficient way of warming an engine up. Just drive it, don't race it until warm!
07-19-2017, 08:48 PM | #14 |
1861
Rep 2,554
This has been covered. BMW states in the manual there is no need for a warm up period. You do more harm than good by letting it idle for long periods of time. Wait for the revs to drop maybe but as long as you remain below 3000 you're fine.
Oh really cold days I'll hold a gear higher than normal for a minute or so and that's usually just to try and get my heat going quicker. These engines are far to advanced to need to warm up in a driveway while you sit there freezing your buns off worrying about your engine that's going to be at 210 degree in 2 minutes. I get what you're worried about though. Just don't romp on it until your temps come up and you're fine. And btw the fuel pump primes when you unlock the car. By the time you sit down and press start engine, the fuel systems been sitting with ample fuel and fuel pressure for about 30 seconds already. |
Antetokounmpo1551.50 Underground6t9316.50 |
07-19-2017, 08:51 PM | #15 |
10
Rep 84
These aren't old warbirds. Just get in, start, ensure car is running, and go! No need to sit and idle.
07-19-2017, 10:14 PM | #16 |
Where'd my VTEC go?
481
Rep 6,067
Electric water pump will keep water flowing as needed even when the car is "off".
07-19-2017, 10:24 PM | #17 | |
///Project Aura
390
Rep 889
Wait for the rpm's to drop (anywhere from 15-30 seconds) and keep it under 3-4k rpms until proper oil temperature. |
07-19-2017, 10:29 PM | #18 |
131
Rep 535
Funny, but never heard of a single failure from not idling engine to warm up. I would imagine if engine would blow up from not warming it up - manufacturer would have placed a 2x4 inch red warning sign in the middle of the windshield permanently engraved
To get oil circulate through engine one needs 3 seconds probably - time it takes for you to put it in a D and drive |
07-20-2017, 12:01 AM | #19 | ||
1861
Rep 2,554
07-20-2017, 09:40 AM | #20 |
271
Rep 790
I don't warm up the car before driving off.
Old cars needed that, not modern cars. Now I do let the engine oil come up to operating temp before thrashing it since I heard that's really bad for n54 engines. |
07-20-2017, 09:46 AM | #21 |
255
Rep 554
Drives: 2013 335is E93 6MT
I just drive off but I don't punch it or high rev it until the oil temp needle has moved a tad. At least I try to do that. It's the only "rule" I know about warming up.
2013 335is E93 6MT | LeMans Blue/Saddle Brown
BQ Tuning MHD E60 flash | Cobb catted DPs | ETS 5" FMIC | BMS DCI | Fuel-It Stage 2 LPFP | MMP inlets/outlets | Forge DVs | N20 TMAP sensor Vibrant 1790 resonators/mid-cat delete | MPI CP | Spec Stage 3+ clutch and steel SMFW | Wavetrac LSD | M3 rear subframe and diff bushings |
07-20-2017, 10:32 AM | #22 |
141
Rep 374
That EngineeringExplained guy on YouTube did a video on this. He seems to be on point about other topics and I find him generally trust worthy. His view is that the longer the engine is cold the more wear. This includes idling while cold. Name of the game is get the engine up to temperature more quickly with LIGHT driving. Drive too hard, engine not lubricated yet and you do damage. Sit idle and engine stays cold longer and also wears more quickly. Light, normal driving is the best compromise. Also as most people have said modern cars are not terribly susceptible to serious damage from cold. We're talking about small gains/losses.
