Nearly unlimited shift knob options
07-13-2017, 12:40 AM | #1 |
433
Rep 780
From what I gather this would likely also work for a manual, but mine is auto.
If this fits better in the DIY section feel free to move it. I was tired of the ugly shift knob, and while there is an option to use the BMW performance knob for the manual, I wasn't interested in spending that kinda coin on something like that. Plus mine lowers the knob height almost 2.5". I'm sure I will receive some severe flaming for this, but this mod allows me to use any Honda (or any M10x1.5) thread. The same thing could be done for M10x1.25 as well. This is how I did it... (I'll get measurements tomorrow, I have to put some loctite on the car side of the threads, so I'll take it apart.) Since I used an angle grinder, I pushed it through a box to catch the metal dust. Then, I cut of the shaft at the groove, and cleaned it up. I threaded the shaft, I found it best to do in N because you can shift back to P and easily vacuum the shavings. It's threaded about 1.75". Basically with the tap in place once you can no longer shift into park stop. This more or less limits how far the stud can go without interfering. Now thread the stud, best with loctite. Reassemble Add preferred knob Very happy with the result I've got a sticker for the top of the knob, it's made to fit the ignition button. |
07-13-2017, 11:23 AM | #2 |
397
Rep 647
I will never understand why people replace their automatic shift knobs and think it makes their car more aggressive.
9
feuer4275.50 6ixSpd6015.50 Underground6t9316.50 ZeeVaughn84.50 Jaronbwall284.50 BSM n54iS2684.50 Zajac1259.50 zero2sixtyZ951.00 tcphoto3537.00 |
07-14-2017, 12:50 AM | #3 | |
433
Rep 780
I didn't care much for the finish that was on it, honestly I planned on going brushed style when I found this one, but wanted to try it out first. Before: Now: |
RealJ221039.00 |
07-14-2017, 11:02 PM | #6 |
851
Rep 2,793
07-16-2017, 12:08 AM | #8 |
433
Rep 780
I appreciate your input but would like to hear (read) your justification. I can understand that you don't like the knob, but am confused by "for an auto."
To me it is effectively like putting aftermarket wheels on, and saying, "the stock wheels look so much better for an auto." It would make sense if I had a knob with an H-pattern, but this is plain. With that said, I really like it and won't be changing it. But I am curious. (You guys will hate it once I get the sticker on! Haha!) |
07-18-2017, 12:41 AM | #9 |
433
Rep 780
I did some light machining and added some grooves. which began as a happy accident but I liked the look so I cleaned it up and kept it. I removed about 3/16" from the top (so it's shorter). It is now more "square" at the top.
The final change, flame suit on, the M. I wanted some kind of BMW badge, but I have black/white roundels and the other option of blue and white wouldn't flow. So here we are, it's my car and I like it. |
05-08-2018, 06:31 PM | #12 |
1209
Rep 2,476
I don't mind the knob, or the M badge. The boot is...meh. The worst part is that awful paint job on the surrounding trim.
zero2sixtyZ951.00 |
05-08-2018, 09:58 PM | #13 |
433
Rep 780
It's just vinyl. I was trying to decide what color to do. So I just rough cut it. I'll pull it off soon. I like the gloss, but as a touch surface gets gross quick. If it weren't my daily I'd jump on it. I kinda like the flat black like the m3, but it just sort of fades into the background.
I'm open to suggestions. I'm going to do the horizontal trim on the dashboard in carbon, so I think carbon would be too much |
05-08-2018, 10:32 PM | #15 |
433
Rep 780
07-06-2020, 12:16 AM | #16 |
Rep 4
hey, man. looking to do this too... could you provide me a link to what you used to thread the shaft? how long was the stud you used? so sick of the butt ugly knob!
07-06-2020, 02:22 AM | #17 | |
433
Rep 780
Remove the stock knob and cut off the excess as shown in the pics. Then use a screwdriver or similar to see where the mechanism disengages. Mark the length on the screwdriver. Then see how much of the rod goes into the knob. Add those together, err on the side of short, I'd say 1/8"-1/4". Use the correct tap. And cut a few turns then back it out to clear it of shavings. I used an excessive amount of the blue locktite on the threads that go into the tapped shaft. And Teflon tape on the end that goes into the knob. Confirm functionality before the locktite cures |
07-06-2020, 02:46 AM | #18 |
Rep 4
thanks for the info, man. so just to be clear, i’d need to get a m10 tap. cut the excess, and stick in a screw driver in the hole and see where it stops? then see how much the stud would go into the shift knob, add those together, and then i’d get the length i’d need? could you clarify on the mechanism i’m checking to disengage? i’m assuming it’s in the hole where i’d screw the stud in?
07-06-2020, 09:55 AM | #19 |
238
Rep 947
Would have been easier to just use a threaded adapter like this:https://www.ebay.com/itm/Universal-A...-/112197569400
My shift knob came with an adapter |
07-06-2020, 10:18 AM | #20 | |
Rep 4
07-06-2020, 12:25 PM | #21 | |
433
Rep 780
07-06-2020, 12:28 PM | #22 | |
433
Rep 780
