07-05-2017, 10:42 AM | #1 |
42
Rep 70
FS - Detachable Towbar
Got a unused, but test fitted towbar for sale. It was test fitted to a F80, but decided not to keep it, as the heat-shield needed too much modification.
Its a Bosal 050-783 - Vertical detachable. Very similar to the Westfalia, the towball itself I think is better because the lock cover is integrated, so its not going to be lost ok, so the bad bits one of the mounting lugs was bent by the courier. I have straightened it. The towbar fits F20/F21/F22, F30/F31 series, and depending on application it holds up a plastic panel, so its not going to be a problem. Secondly, the plastic plug that fits into the receiver when the towbar is not inserted was cracked, so I have glued it back with epoxy. I've got the instructons somewhere, but if i can't find them, I will print off a set. Would like £100 for it. Collection only from NW London - its quite heavy!! |
