Subframe off what else should I do?
07-03-2017, 05:56 PM | #1 |
224
Rep 553
Picked up a 2010 335 as a project. Car he 122k miles.
The subframe is coming down to address the oil pan leak and to install inlets and Catless down pipe. Also going on are KW v1 and the upgraded control arm bushings and new upper/lower control arms. What else should I take care of? Rear upper shock mounts and new end links. Since the subframe is lowers I was thinking m3 subframe bushings or would you guys stick to power flex inserts? And lastly to wrap it all up I was thinking of throwing on e9x m3 front and rear swaybars? Anything else I should do when all this work is being done please let me know so I can order parts |
07-04-2017, 09:51 AM | #2 |
141
Rep 436
i really like the m3 subframe bushing upgrade
fyi - if you have xi/awd the m3 front swaybar wont fit
Dinan Stage 3/Cobb FMIC/ER Sport Oil Cooler/CPE Catted DP/BMS DCI/Eisenman Race/Koni Yellow F + Dinan R/Dinan Springs/UUC F + R Sways/M3 subframe bushings/OEM 313 Wheels/M3 steering wheel
07-04-2017, 10:58 PM | #3 |
238
Rep 947
There are no subframe bushings for the front subframe.
M3 bushings in the rear subframe do help though and a rear sway when you do the rear subframe will save on labor. |
07-06-2017, 07:27 PM | #5 |
Touring cars rock
351
Rep 907
Don't use M3 bushings, go solid. There is no difference in NVH. The handling difference is profound. Just because it came out of an M car doesn't make it better.
I'd do high durometer poly on the diff as well as the transmission while you're there. If you have it all out, put a rear bar in and solve the push under steer once and for all. Don't go too big like most people do. With the OE front bar an M3 bar should do just fine and restore good balance to the car and improve turn in. These cars DO NOT need more front bar. Replace the upper shock mounts with the high durometer poly too, makes the shocks work better. They are cheap, like $25 for the set. I used the Strongflex ones and they are very good.
Sportwagon Daily: I've done some stuff.
07-07-2017, 11:32 AM | #6 |
224
Rep 553
Thanks for the reply guys esp ninteyone .
Can I use the upgraded shock mounts with the KW v1. Coils? And do you guys know the best place to buy the solid rear bushings? |
07-07-2017, 12:05 PM | #7 |
Touring cars rock
351
Rep 907
The ones from MRF Engineering are VERY well regarded: http://www.mrfengineering.com/mrf-en...e-bushing-set/
You can use the strut mounts with any strut, they replace the sponge-o-matic OE ones that do nothing but compromise damper performance. You can get the Strongflex ones from them directly. Don't bother with the softer red ones, you won't get any more vibration from the yellow: http://www.strongflex.eu/en/e81-e82-...553503418.html
07-07-2017, 12:11 PM | #8 | |
224
Rep 553
In addition to this strut mount bushing do you suggest anything else ? I'm installing kw v1 I heard the strut top hats should be done too? The car has 122k miles. |
07-07-2017, 12:16 PM | #9 | |
Touring cars rock
351
Rep 907
Get the correct 90A poly bushings for the rear bar too, it's a different diameter than OE so make sure you double check that, but the clamps which hold the bushings are all the same outer dia. As mentioned above, the M3 bar may not fit, but UUC makes a good rear bar. I'd use the red poly on the OE front bar. The front and rear subframes need to be aligned to each other. You need a frame jig for that. You may not think it's a big deal, but it is. Also, make absolutely all your suspension and arm bushings are not torqued till you get the car corner balanced at the correct ride height, then go back and torque it all down at height or you'll trash your new bushings. I usually do this all on an alignment rack at a friend's shop.
07-09-2017, 02:25 AM | #10 | |
65
Rep 515
i am very sensitive to nvh but would be open to try the solid bushings but not just for a negligible handling diff |
07-09-2017, 04:47 AM | #11 |
401
Rep 1,425
Transfer case fluid. That's a must. Changed mine at 70k km. Pretty damn black.
3IM . Okada Plasma Direct . Euro Ram Intake . AA header (Pending) . PE . 2nd Cat Delete . F30 340mm 6 pot . EBC Yellow Stuff . StopTech SS Brake Line . BMW Performance CF Strut Bar. 219M . PSS
07-09-2017, 02:14 PM | #12 | |
Touring cars rock
351
Rep 907
If you're just going to daily it, there will be zero NVH difference with the poly over the OE, and it'll be a big improvement. The solid ones are night and day difference. If you like the handling of a new M, this is the direction you want to go. These cars are really heavy, you want to get the big rubber bits out of them if you can.
miker201365.00 |
07-09-2017, 07:07 PM | #13 | |
65
Rep 515
the subframe front/rear bushings in yellow? shock absorber upper mount?? roll bars?? all yellow? |
07-10-2017, 07:34 PM | #15 | |
65
Rep 515
thanks for you input... my build is gonna be epic can't wait to get it together |
07-17-2017, 04:48 PM | #16 | |
Touring cars rock
351
Rep 907
If you don't plan to upgrade the rear bar you should consider leaving the OE in front and going to yellow in the rear.
