07-03-2017, 06:24 AM | #1 |
Doc Brown
1176
Rep 2,174
P112F CEL
So lately I have been getting a P112F CEL . I have done a little research and not come up with any real solid answers, they seem to be all over the place. I have seen:
Manifold Absolute Pressure to Throttle Angle - Too High (Bank 1) and I have also seen this: P112F 1st time - MAF sensor P112F 2nd time - throttle body P112F 3rd time (became a puma case) - waste gate actuator P112F 4th time (puma case reopened) - cylinder head had a crack in it. replaced cylinder head and a worn piston The light clears with a scan tool but comes back on. Anyone else been getting this? I have a Fabspeed HFC and JB+ installed. Thanks.
07-03-2017, 10:38 AM | #2 |
150
Rep 485
What's your setting on the jb+? Might try turning it down a bit if it's at max.
DragonGate71.50 |
07-03-2017, 10:42 AM | #3 |
Doc Brown
1176
Rep 2,174
Yeah, it is cranked all the way up. I was thinking of turning it down to see what happens. I have had it in the car for almost 8 months so it is strange that it would come on now.
07-05-2017, 09:48 AM | #7 |
Doc Brown
1176
Rep 2,174
I am gonna turn it down and see if it continues. It is just so strange that I have been running it for as long as I have with no issues until now.
07-05-2017, 10:17 AM | #8 | ||
IG @bmwF9xG80
3813
Rep 7,593
I think this would be the best
Did you switch gas grade or station? I know someone who got a CEL when he used speedway or raceway gas, switched to a TopTierGas brand and CEL went away. I'm pretty sure car is not liking the jb+ on max in this weather (lack of Cooling/Airflow)
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
cookiesowns587.00 |
07-06-2017, 07:28 AM | #9 | |
Doc Brown
1176
Rep 2,174
10-09-2018, 09:50 AM | #10 | ||
40
Rep 114
So out of the blue I am getting the same P112F code. I too have the JB+ and a Fabspeed sport cat, but also a CTS intake. My JB+ has always been set at #3, as I heard it may not like being turned all the way up. Maybe I have an old scanner (Actron) but I can't delete the code. My scanners shows the code as "Permanent". So i don't know what to do? Twin Fed, did you figure out the cause.... Any advice on a fix or clearing my code? Thanks
10-11-2018, 10:51 AM | #11 | |
Doc Brown
1176
Rep 2,174
Since turning the JB+ down to around midway, I think that I only got the code once or twice. But it cleared, it never hasn't. I used a cheap $60 code reader/clearer. I have also since installed a FMIC, charge pipes and intake. I will definitely say that it does not like being turned up all the way, especially in the warmer weather. I would take it out, disconnect the battery. Let the car sit for an hour and then reconnect the battery and start the car. If the code is still there try and clear it again. If it clears drive the car without the JB+ for a while and then lower the JB+ and reinstall it and see what happens. Let us know.
10-16-2018, 11:35 AM | #12 |
motorhead
57
Rep 465
Had a JB+ and had the same P112F code. Went from Max, to 5, to 3 to out!
The code would drop off after about 6-8 new starts, but still a pain. IMO it is not suitable for the M2. |
01-21-2019, 10:01 AM | #13 |
2709
Rep 1,538
sorry for the old bump, but people who got this code, get rid of it by removing the JB+?
Got the same code on my 2013 N55, but after 6 month using the JB+. Note that the car is running fine, and still pull hard, I felt no difference at all. I can't really play with the setting, since its a 1st gen JB+ (the one with 4 plugs on it), and with the latest BMS software, the reading are inaccurate (see picture). The code appeared after a really cold morning (-24°C drybuld, -11°F)... It might be related... |
01-21-2019, 01:06 PM | #15 |
2709
Rep 1,538
thanks,
any thought on the JB4 ? A good friend of mine is selling his JB4 since his M235 go back to the dealer. 160$, its a steal ! but I wont get into all the installation process if its not better... |
01-21-2019, 01:45 PM | #16 |
Doc Brown
1176
Rep 2,174
I don't really have any thoughts on a JB4, sorry. All I can tell you is that, that would not be the direction I went in if I was planning on really tuning my car.
01-21-2019, 02:09 PM | #17 |
5865
Rep 6,635
I feel like unless you're using it as a meth controller, JB product is not something to be used on an M2. Too many stories and flash tunes exist for reasonable price.
01-21-2019, 02:17 PM | #18 | |
2709
Rep 1,538
On my dd audi, I did not use a piggyback, I got a real dyno tune, ecu flashed and lot of parts... the bmw is the 2nd car ... : - wife said : keep it stock - friends said : keep it stock. - the whole world told me to keep it stock - me : ahh, just a piggyback, set of wheel, exhaust, suspension, anddd im done low safe value on the JB shouldn't be a big problem according to my reading... until this code. lol. |
01-21-2019, 02:22 PM | #19 |
Doc Brown
1176
Rep 2,174
Yeah, my car is still under warranty too, that is one of the reasons why I have not pulled the trigger in a real tune. Especially since one of my injectors went bad and they were pressing me hard about a tune. My stock is only changing the DP, Intercooler, Charge Pipes, Intake and JB+, LOL.
01-21-2019, 02:27 PM | #20 | |
333
Rep 390
Dont really need or want the flash. |
02-03-2019, 02:58 AM | #21 |
587
Rep 898
Oh gosh. The fact that you guys are getting warranties done with a Jb+ or JB4 just means you’re lucky.
People who think running a piggy back or worse a dumb device that simply reducing reduce voltage on the MAP sensor baffles me. The M2 has a overboost mode that other N55’s don’t. Because of that it runs about 13-14psi when overboost is running and roughly 11psi without on the stock tune. Using a pure additive tuner will be a very bad idea as the engine won’t see the additional boost until it does a MAF plausibility check along with the increase in fuel consumption. You’re lucky the M2 targets relatively rich AFRs. I guarantee the OP cracked a cylinder head due to lean condition with the JB+ |
02-03-2019, 03:13 AM | #22 |
333
Rep 390
It's been flawless for me on Map3.
I apologize if every other person who's had first hand knowledge had a bad experience with the JB4. Would not run the JB+ though. But we do have options so that's always good! Not everyone will jump the wagon and go MHD or BM3 if they don't find it necessary. |
