07-02-2017, 03:06 PM | #1 |
9
Rep 36
2015 330d 8AT Jerky after start stop and when in sports transmission
Hello folks,
Does anyone else get the title? If you accelerate straight after start stop the car seems to want to go, delays and then goes for it. If you allow the car to start after a start/stop and give it a second or so before you let your foot entirely off the brake you can then accelerate away smoothly. The second potential issue I have is that if I am in sports transmission or using the paddles the car will most often jerk when changing gear under lighter acceleration in this mode. When pressing on its smooth its just when under lighter loads it will jerk you back and forth (rough gear change). Is this just normal due to the car expecting you to want to GO? PS tried a transmission reset, still does the above. Thanks all |
07-02-2017, 05:11 PM | #2 |
SQUEAKY
104
Rep 322
You might be experiencing the turbo lag from your first point.
For the second example, do you have the sports tranny or just standard? Just for clarification, the tranny itself, not the sports driving mode selector. If you have sports+ available, then it's the sports tranny. |
07-02-2017, 05:15 PM | #3 | |
9
Rep 36
I have sports tranny, its when the gear lever is to the left. |
07-02-2017, 06:16 PM | #4 | ||
303
Rep 1,134
