06-17-2017, 09:20 AM | #1 |
172
Rep 168
Drives: 2021 F93 M8 Competition
M550 exhaust flaps open = much better sound
As many of you are aware, the M550 has two electrically-actuated exhaust flaps, one in each of the outer exhaust pipes on the rear exhaust. Given I can't see the inside of the rear muffler, I'm not certain what the characteristics of the muffler are for the outside pipes.
I removed the tensioned bow spring (7) between the actuator and the flap, and moved the flaps to the open position, held by zip ties through the slotted head connected to the flap (melting point of nylon is about double max exhaust system temp — just did this as a test). The sound is much better at idle and normal city driving, and no error conditions are tripped. It's not a big change, but it's definitely an audible and welcome change, and is what I expected something like a M550 to sound like. Something worth considering for "free". (Disclaimer: Yes, I am aware this is not a "BMW-supported" configuration, and may change the sound (duh), emissions, or other characteristics of the exhaust system.) |
06-19-2017, 08:15 AM | #3 |
172
Rep 168
Someone privately asked me for more detail, but I was not able to respond directly by private message...here it is:
Once the bow spring is out (and it's not fastened to anything -- it's just under tension), the flap moves freely between its open and closed positions. So freely, in fact, that it will rattle if it doesn't have something holding it in a position. So basically, the zip tie (or you could use heavy wire, or similar) just goes around the whole pipe where the flap is, over the external "axle" part of the flap where the spring used to be, to hold it in the open position. It doesn't take a lot to hold it, but it takes something. There is probably a better option than a long zip tie, but it seems to be working just fine for me. Last edited by daveschroeder; 06-19-2017 at 02:56 PM.. |
TexasM550i63.50 Mbbrewer150.00 |
06-19-2017, 03:05 PM | #4 |
172
Rep 168
7
TexasM550i63.50 Sonny325gm26.50 DeeKay553.00 Sheharyar_rr236.50 nate196122.50 FSociety3812.50 HomeIn2327.00 |
06-20-2017, 09:07 AM | #5 |
553
Rep 646
Sounds amazing
| 2021 Tesla Model 3 |
06-20-2017, 03:09 PM | #6 |
120
Rep 221
Ok, so no DIY video
But can you walk us through the process? The diagram is great, just wondering the sequence for all those parts on your spec sheet.
Daily: 2023 i7 xDrive60
GONE: 2022 X7, 2019 750i, 2016 M4 Competition, 2014 550i, 2008 335i, 2005 MINI Cooper S, 2002 X5 3.0, 1999 328i |
06-20-2017, 03:47 PM | #7 |
172
Rep 168
Literally you are removing part "07" on both sides, moving the flap 90 degrees to the open position, and then putting something around the outside of where the flap is, touching the part where the bow spring used to be, to keep "pressure" on it so it doesn't vibrate and stays open. That's it. :-)
I removed the spring by putting a little pressure on it to compress it (using a screwdriver) in the axis perpendicular to the pipe (the way it flexes), and it came right out. Just be sure it doesn't fly off somewhere when it comes off. People have done this on other BMWs that have vacuum-actuated flaps, or unplugged the electric actuators when they are open. I thought this would be the "easiest" way on this vehicle. |
sitcom323119.50 |
06-20-2017, 05:50 PM | #8 | |
120
Rep 221
Anyhoo, THANKS! Had a 2014 550i, and now in a '16 M4 -- yeah i know completely different cars -- but thinking I want to go back to the Executive Jet world
07-11-2017, 11:18 AM | #9 |
172
Rep 168
Note that the flaps can also be coded open, including with apps like BimmerCode or BimmerLink.
07-11-2017, 03:56 PM | #10 |
Rep 20
For the G30 there is not yet support for exhaust flap opening in BimmerCode. They responded to a post I made on Facebook yesterday asking if this is available.
07-11-2017, 03:57 PM | #11 |
172
Rep 168
Ah, it appears to be there, but I did not try it since I had already removed the bow springs. Thanks for the update.
02-24-2018, 06:38 AM | #12 |
Rep 1
Hello, I'm new here but reading posts for some time. I saw this post and decided I wanted to help a little. I did the same thing to my M550i exhaust flaps and I agree, the exhaust sounds a lot better! I did the zip tie method as well but one came loose and it started rattling again. Here is a much easier way to get this done, no coding required. When you start you ignition the flaps are all the way open for about 30 seconds. In that time you need to get under your car and remove the plug from the valve. Try removing it before to get an idea of how to open the clip with a screw driver. If the flap is open and you remove the plug, it stays open. I tied the plugs of and tied the cables to the bumper inside. I have been driving around like this for 4 months and no errors and issues. Don't put in Sport plus Mode and let idle, yes the flap is open but not completely, only when the throttle is pushed. Ignition start is easier. You don't have to remove the spring this way. Good luck...
02-24-2018, 01:34 PM | #13 |
Rep 27
What would happen if left idling in sport plus by doing it this way?
BigMofoFrog180.50 |
04-02-2018, 11:11 AM | #15 |
Rep 29
Flaps
Is the only Flaps , the flaps that you see in the outer exhaustpipe on each side ? Or is it any flaps that you can't see from the back. After following the tip, my flaps as I can see in the outside pipe is in total open position, and the sound is better when throttle but still most aggressive sound the first seconds after the engine has start. Do you have the same experiance ?
04-02-2018, 11:12 AM | #16 | |
172
Rep 168
apiccus3.00 |
04-04-2018, 04:14 PM | #19 |
3399
Rep 6,593
Drives: BMW
I have an even easier way to accomplish this!
Did this on my previous F82 and while that was fun, the cold start of the F82 with the flaps open all the time was obnoxious. And this sounds better.
Ready for it..... Pull fuse F203! 1) Turn car on, put in sport. *Ensure the flaps are open 2) Go into trunk, pull fuse F203 (while car is still on) 3) Verify flaps are still open 4) Close trunk 5) Enjoy Exhaust Flap wiring diagram: https://www.newtis.info/tisv2/a/en/g...use/1VnYS9CGy7 |
7
05-31-2018, 06:56 PM | #20 | |
Rep 33
If I'm reading this right then the flaps would be mostly open, but not 100% open like within the first 30 seconds of firing up the engine. Can anyone verify if this is the case? |
05-31-2018, 08:45 PM | #21 |
376
Rep 1,223
So, is the coding in Bimmercode app for this?
2018 M550iX-Dinan Stage 1 | 2011 E93 M3 Convertible | 2002 E46 M3 Convertible | 2002 E53 X5 3.0 | 2000 E39 540i | 1998 E36 M3 | 1988 E28 M5 | 1987 E28 528i
06-01-2018, 12:57 PM | #22 |
IG @bmwF9xG80
3813
Rep 7,593
I have BimmerCode but not yet M550 you should try it as it gets updates and you can code a bunch of other cool features.
BimmerCode is very user-friendly as well
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
