M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Dual exhaust (Stock)- uneven exhaust flow?
      06-16-2017, 05:16 PM   #1
AGM2
AGM2's Avatar
Drives: M2 LBB 17
So, not sure, if I've just never noticed this on other cars I've had with dual pipes, if this is normal to the M2, I do see quite a bit of black soot on the bottom of the passenger side exhaust.I cannot see anything out of the driver side . If anyone has a more technical take on this please post and definitely let me know if I am not correct. I'd love to know more about it.
      06-16-2017, 05:38 PM   #2
drewF87
26
Drives: '17 BMW M2 AW, 6MT
mine is dirtier on the passenger side as well. it's normal.
      06-16-2017, 06:57 PM   #3
Semi-Poor
Semi-Poor's Avatar
Drives: 2017 M2 Coupe
Valve opens on that side = more mess
2017 M2 Coupe Black Sapphire Metallic
      06-16-2017, 08:08 PM   #4
SeanWRT
SeanWRT's Avatar
3179
Drives: E90 M3 & F87 M2
Valve is on driver's side (LHD).
Lemania 2320
      06-16-2017, 08:43 PM   #5
slick///m2
Drives: '17 M2 AW DCT
I believe It depends on your setting when you drive. If you drive mostly comfort mode the passenger side gets dirtier. If you drive sport/sport+ then both sides of the exhaust tips get dirty.
      06-17-2017, 02:54 AM   #6
JLX
JLX's Avatar
71
Drives: '17 F87 M2 DCT
2017 BMW M2  [9.50]
I have a BMS OBDII Canflap module, I drive with both my valves open all of the time. I still have more carbon buildup on one side relative to the other. Maybe the exhaust also has an inherently uneven flow?
      06-17-2017, 10:41 AM   #7
OG///M
Always +10MPH
OG///M's Avatar
Drives: 6MT
Mine is equally dirty on both sides. That's just the M2's way of telling you need to drive in Sport+ and go over 3k rpm more
D CHOI581.00
      07-14-2017, 09:56 AM   #8
TampaF87
85
Drives: M2
Gasses will flow along the path of least resistance, just like water. There is obviously less resistance under cruising speeds for the passenger side. As others have noted, when they drive more aggressively, both get dirty, which adds some credence to the theory lol
m2
