M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Phone mount/holder
      06-11-2017, 03:17 PM   #1
mrmjk
mrmjk's Avatar
126
Drives: BMW M2 Sapphire Black
Phone mount/holder
Which phone holders/mounts do you recommend or do you use in your M2? Excited to see what you guys are using
      06-11-2017, 03:20 PM   #2
M2OG
400
Drives: a car
Curious about this too. I was thinking about making a dock that would sit in one of the cupholders so I can just get it and pop the phone into the cupholder the same way you would use a desktop dock. Tap the power from under the console so you don't have any cables anywhere. If I ever get around to making it I'll post.
mrmjk125.50
      06-11-2017, 03:22 PM   #3
mrmjk
mrmjk's Avatar
126
Originally Posted by Natek View Post
Curious about this too. I was thinking about making a dock that would sit in on of the cupholders so I can just get it and pop the phone into the cupholder the same way you would use a desktop dock. Tap the power from under the console so you don't have any cables anywhere. If I ever get around to making it I'll post.
Sounds really interesting. I find the magnet (wireless charging included via the case provided) mounts best... but not sure about using the case all the time.
      06-11-2017, 03:27 PM   #4
M2OG
400
Drives: a car
I agree. Wireless charging is only cool if every charger you use is wireless. But they're also slow which is why I think one wouldn't use wireless chargers exclusively. Otherwise is a PITA to swap/remove the case all the time.
      06-11-2017, 07:41 PM   #5
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
Proclip. Excellent all around easy to route wire to armrest and location is ideal of using OBD torque pro app for data while driving.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      06-11-2017, 08:21 PM   #6
snipersix
snipersix's Avatar
228
Drives: Retired 2017 F87 M2
2017 BMW M2  [0.00]
I use this https://us.macally.com/products/MCUP
2017 M2 Coupe:|Black Sapphire Metallic|DCT|Nav/Idrive|M Performance CF Spoiler|M Performance CF DCT Interior| M Performance Gloss Black Kidney Grills| M Performance Steel Pedals | Eventuri CF CAI | 19" Brixton Rims | KW V3 Clubsport |
Retired: |2008 328i Sedan|Montego Blue|
      06-12-2017, 12:53 AM   #7
izzyM2
izzyM2's Avatar
704
Drives: 24’M2/21ID.4/21’MacanGTS
Right smack in the middle.
Good: right in center, two additional USB ports, easy to adjust, very stable and no vibration, It has this rubber piece for a tight fit in the cigarette port.
Bad: close to the shifter and obstructing the climate control area.
Appreciate 2
mrmjk125.50
M2 Blur125.50
      06-12-2017, 01:21 AM   #8
dj2020
94
Drives: M2
This is my set up:
Wireless Qi charging with magnetic mount. No plugging lightning cables. It's a very clean look but does block the cup holder when in use. I run Waze in the background with this set along with CarPlay.
http://www.ebay.com/itm/112237539163...%3AMEBIDX%3AIT
http://www.ebay.com/itm/400957270682...%3AMEBIDX%3AIT
mrmjk125.50
      06-12-2017, 12:47 PM   #9
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
I just use magnet mounts. I clip one onto the air vent in centre console. Works great! And when not in use you barely notice the little magnet mount.
      06-12-2017, 01:07 PM   #10
mrmjk
mrmjk's Avatar
126
The only problem that I have with the magnet mount is that I get bored of using an iPhone case.
Anyone using this one? https://www.amazon.com/Breffo-Spider.../dp/B003Y419K4
      06-12-2017, 01:12 PM   #11
mrmjk
mrmjk's Avatar
126
Which one are you using?
M2 Blur125.50
      06-12-2017, 01:25 PM   #12
recycledAlva
290
Drives: MY17 BSM M2
2017 BMW M2  [0.00]
https://www.amazon.com/dp/B00PGJWYJ0..._hWTpzb8DD5CEG
This is what i've been using. I had my phone mounted on it while i was at the track and it never budged.
Appreciate 2
mrmjk125.50
Aronis2270.00
      06-15-2017, 12:37 PM   #13
izzyM2
izzyM2's Avatar
704
On my post above. If I just face the phone towards me I get more clearance from the DCT and I can see the climate control ui better and you can still use the cupholders.
      06-15-2017, 05:58 PM   #14
PiK
PiK's Avatar
Poland
61
Drives: M2 6MT
Here is mine - iOttie Easy One Touch Mini CD Slot Mount.
https://www.iottie.com/Product/Detai...-_-Smartphones
      06-15-2017, 09:12 PM   #15
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
I'm using this. I use it with a case but you could simply peel and stick directly to the phone and use without a case.
It's discreet when not in use and clean looking when in use since u only see ur phone floating in front of you. You can also mount it horizontally or vertically...magnets are quite strong. I was skeptical at first about the phone staying put when going over bumps etc but it doesn't budge!
      06-16-2017, 02:41 AM   #16
mchoy
Drives: LBB LCI M2
I've been using the Kenu Airframe for years. Very low profile and clean looking.
https://www.amazon.com/Kenu-Airframe...7598683&sr=8-1
(other phone options available via search)
      06-16-2017, 04:34 PM   #17
MR.
MR.'s Avatar
4398
Drives: BMW M2 CSL Turbomeister
Belkin Car Cup Holder Mount
      06-16-2017, 05:44 PM   #18
drewF87
26
Drives: '17 BMW M2 AW, 6MT
Originally Posted by snipersix View Post
i use something similar to this but it has a magnetic mount instead.
      06-16-2017, 09:47 PM   #19
Rock Sweden
Rock Sweden's Avatar
Drives: 2016 M2
I had/ have one in my car but don't use it anymore, in fact I havent seen it in months. I assume it's under a seat somewhere. It is super adaptable holds the phone well but has some shake and if using in the airvent it makes the vent unadjustable. Now I just drop it in the cupholder.
mrmjk125.50
      06-18-2017, 11:45 AM   #20
mrmjk
mrmjk's Avatar
126
Awesome tips and contributions! Thanks guys. I'm going with the simple magnetic mount and a quick charger. I like my interior clean so I said it's better to keep it simple and easy.
      06-19-2017, 01:18 PM   #21
Aronis
Aronis's Avatar
2270
Drives: 2018 M5
I have seen that one before. Do you have any photos of it actually in your car so we can see the height and position?
Thank you,
Mike
2018 M5 and 2019 Porsche Boxster GTS
Prior. '94 325is, '97 M3 Lux, '16 M2
      06-24-2017, 01:48 PM   #22
ZPrime
I INDIC8
ZPrime's Avatar
Drives: 2018 LBB M2, 6MT
2018 BMW M2  [9.50]
Normally I do a Proclip mount, but it looks like that will block the vents on the 2er? I don't like losing vents to phone mount, plus I was planning on putting in the Awron gauge which will already kill one...
2004 Matrix XRS 6MT => 2008 VW R32 DSG => 2012 Audi TTRS 6MT => 2018 BMW ///M2 6MT
I'm an IT guy by trade and tech nerd by choice.
I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway.
I'm also a fan of aural pleasure.
m2
