Tapping noise coming from front driveshaft.
06-06-2017, 08:37 PM | #1 |
40
Rep 80
So I was getting some lunch this morning, while pulling up at the drive thru window I could hear a tapping noise reflecting off the wall while I had the window down, I pulled up to a parking spot and looked underneath the car to see if I could see anything out of place, I grabbed the from drive shaft and tried turning it by hand and I heard the same noise, it sounds like there is slack on the u-joint and it makes a tapping noise while under load at low speeds.
I drove with the window down for a while and only heard it once, it's not constant, and it happened at a low speed like 5 and under, im thinking its the driveshaft but I won't know for sure until the weekend when I get one of my friends to come help me diagnose the car, does anyone know what this might be? I been searching for the last hour but none of the threads I found seem to mention my problem. Thanks guys. |
06-08-2017, 05:21 AM | #2 |
Rep 17
Since you haven't had any replies thus far, I'll offer up my 2 cents: My wife's '07 328xi w/ 150K miles on it had a high freq vibration that I associated with a front bent rim. Turns out that the front driveshaft rear u-joint (transfer case end) was going and it failed badly (co-incidentally on the day you posted). The u-joint was so worn that the yoke that attaches to the xfer case output shaft broke and the shaft nearly separated. It took out, at the least, the xfer case seal...and possibly the bearing. I'm still disassembling and searching parts. I say all this because I've searched and found that this is not uncommon. Check yours closely this weekend...
06-08-2017, 07:49 AM | #3 | |
2341
Rep 3,539
https://www.fcpeuro.com/products?keywords=26128615622 Also, could you please update your profile to show what year and model you drive. |
06-08-2017, 10:39 PM | #4 | ||
40
Rep 80
You freaking rock dude, I been reading a lot about this and it does sound like my problem, I just didn't exactly knew what terms to use in my search, thanks. |
06-09-2017, 12:14 AM | #5 | |
45
Rep 225
06-09-2017, 06:36 AM | #6 | |
Rep 17
06-09-2017, 08:44 AM | #7 | |
45
Rep 225
Going to have it checked out. Glad I found this thread. |
