2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning Diminished performance after first oil service
      06-03-2017, 04:46 PM   #1
AlexM240i
102
Drives: M240i
Unhappy Diminished performance after first oil service
Hi.
A couple of days ago my M240i had it's first oil service at the dealer.
They put 6.5 liters of oil and changed the oil filter. Didn't change the air filter because "the car doesn't need it yet" according to the BMW system...
From the moment i drove away from the shop, i noticed diminished performance of the car (acceleration, revving speed, among others).
What could be the cause of that ??? Too much oil added? Incorrect viscosity oil ???
What are your thoughts ?
      06-03-2017, 07:18 PM   #2
xantdieselx
Kingslayer
xantdieselx's Avatar
411
Drives: 23' M3 Base
Originally Posted by AlexM240i View Post
Hi.
Did they do anything else like a software update? Check your copy of the work order. Sometimes the dealers will perform updates or recall work without mentioning it. Maybe the disconnected the battery and trans was reset?
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i
Current Cars: 2019' X3, 2021' M3 Comp
      06-03-2017, 08:30 PM   #3
overcoil
3074
Drives: M235i 6spd
Also use the iDrive to check oil level.
And check under the hood to make sure they didn't leave a fender cover in there strangling the intake air.
shark715166.00
      06-04-2017, 08:07 AM   #4
AlexM240i
102
Drives: M240i
No aparent software update on the work order. What can i do to fix it if they disconnected the battery ?
qballis270.00
      06-04-2017, 08:10 AM   #5
AlexM240i
102
Drives: M240i
Oil level is ok (MAX level) according to iDrive and no strange objects obstructing the air intake....
The incorrect viscosity of the oil (too thick) can cause this ???
      06-04-2017, 08:59 AM   #6
overcoil
3074
Drives: M235i 6spd
I don't think any motor oil viscosity that a BMW dealership would use in any of there cars could result in noticeable power-loss. But I'm not positive.
If they bent the exhaust on the bottom of the car crimping the tubes restricting exiting exhaust?
And no check engine light ?
      06-04-2017, 02:09 PM   #7
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
Maybe try a TBA reset
http://www.2addicts.com/forums/showthread.php?t=1020477
      06-05-2017, 10:11 AM   #8
AlexM240i
102
Drives: M240i
Checked the midpipe also and it's fine. No check engine light so far....
      06-05-2017, 10:15 AM   #9
AlexM240i
102
Drives: M240i
Originally Posted by pikcachu View Post
Done it yesterday. I'm gonna give it a couple of days to see if it goes back to normal...
The oil level is at MAX according to iDrive. I guess this is normal ?
      06-06-2017, 02:39 PM   #10
chris240
7
Drives: M240i estoril blue mt
I don't know if oil viscosity could be the cause of your problems but don't assume the dealer gave you the right viscosity. My dealer put in 5w30 in my engine when they should have used 0w20. I only caught their mistake after looking closely at the invoice. Lesson learned... don't assume anything and question everything.
AlexM240i101.50
      06-19-2017, 01:12 PM   #11
theMpower
Spain
12
Drives: G82 xDrive + G20 M340d
Make sure they haven't updated your car ... You should check the I-Step from ISTA or E-Sys. You can also export the user profile to a USB.
I have experienced loss of performance in the F020-17-03-503.
AlexM240i101.50
      06-19-2017, 10:26 PM   #12
AlexM240i
102
Drives: M240i
I didn't understand what i should do...
      06-20-2017, 08:31 AM   #13
AlexM240i
102
Drives: M240i
That's true. I just figured out my dealer is not using the recommended viscosity oil. They put 5w30 instead of 0w40 as BMW recommended. What can i do about it ??? Does this have any influence in the above mentioned diminished performance ???
2addicts
