BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > All-Wheel-Drive (Xi / xDrive) Talk > Best way to launch with AT xi?
      06-01-2017, 01:27 AM   #1
JUST8AV8
JUST8AV8's Avatar
Drives: 09 Pure Stage 2 335xi
I'm wondering what people have found to be the best method for launching to get the best quarter mile time.
1. Launching in Sport mode
2. Launching in Manual mode starting in 1st gear
3. Launching in Manual mode starting in 2nd gear
I know a lot of people with RWD launch in 2nd for traction issues but I don't seem to run into any traction issues with my XI even upgraded turbos. Thanks
09 335xi AT, Pure Stage 2 'DD' turbos, JB4 G5 ISO w/anti-lag, MHD Trebila tune, Fuel-It Stage 2 LPFP, NGK 1 step colder plugs, BMS meth kit w/dual cm7, BMS DCI, VTT inlets/outlet, RB PCV valve, BMS OCC, N20 tmap, Cyba Scoops, Lux H8 160, VRSF 7" FMIC, VRSF DP, Custom exhaust, VRSF Chargepipe, GFB SV50 BOV, ER Sport Series Oil Cooler, UUC front sway, M3 rear sway w/powerflex bushings, BC Racing coilovers, xHP Stage 3, Hawk HPS 5.0 brakes
      06-01-2017, 08:34 AM   #2
Jeff@TopGearSolutions
Jeff@TopGearSolutions's Avatar
Manual, 1st Gear, Brake Boosting - not the best for your transmission or drivetrain though. Oh and get ready to shift and turn off traction control.
      06-01-2017, 09:14 AM   #3
JUST8AV8
JUST8AV8's Avatar
Thanks Jeff. Yeah I tried to launch in Manual mode, 2nd gear, brake boosting but it felt slow. Felt like the tranny was slipping. I wish it shifted faster from 1st to 2nd without the feeling that you get a sudden loss of power between shifts. Shifting in higher gears feels great though.
      06-01-2017, 10:16 AM   #4
Do you have the Alpina Flash or XHP Trans Flash?
My 1-2 shift is lightning fast compared to stock, was on Alpina and now I'm using Stage 3 XHP.
If your tranny is slipping, I'd change the fluid and mechatronic sleeve ASAP & I wouldn't plan on doing any more launches if you want to extend the life of it.
      06-01-2017, 11:25 AM   #5
Nonecure
Nonecure's Avatar
Drives: 2013 M3
I found shifting 1 to 2 around 5.5k and the rest of the gears around 6k worked the best for me. The Alpina Flash shifts fast, but the rpm's moves fast too. So if you shift when the needle is at 5.5k, it ends up a little after 6k when it really shifts (maybe my shifting hand is slow). If you look at the torque curve of a FBO with stock turbos, you want to keep the rpm's low.
      06-02-2017, 05:46 AM   #6
HydroStream6
88
Drives: F15 X5 50i M-Sport
How does the xHP Stage 3 compare to the Alpina? I can't seem to find a good comparison. I've got the Alpina now and am happy with it (and it's free).
Thanks!
      06-02-2017, 12:18 PM   #7
JUST8AV8
JUST8AV8's Avatar
I was running the alpina but switched to xhp stage 3. I've been using xhp stage 3 since it was first released. Using version 2.1 right now.
I only have 48k miles on my car. Do you think I need to change the trans fluid and mechantronic sleeve already?
It only felt like it was slipping that one time I brake boosted and launched in 2nd gear(manual mode).
      06-02-2017, 12:20 PM   #8
JUST8AV8
JUST8AV8's Avatar
I like it better. D mode is definitely better and it seems to shift a tad faster than alpina and definitely downshifts a lot faster.
Thanks!
      06-02-2017, 12:22 PM   #9
Yea first gear comes and goes quick and I had an MT RWD prior which would result in 2nd gear breaking both tires loose no matter what LOL
Thanks!
It really depends if you find any drawbacks to Alpina. If you don't then it's probably not worth changing. However, if you don't like Drive in Alpina or you want quicker shifts in sport and M mode, XHP may be worth upgrading.
I personally can't stand Drive in Alpina and the shift speed in XHP Stage 3 were noticeable enough for me to justify the purchase.
      06-04-2017, 08:56 AM   #10
jetdriven
Drives: 2009 335i Xdrive sedan
The stock dme and alpina flash limits torque while brake boosting, th boost wil go to about 2 PSI around half throttle, then if you go above that, the torque limiter kicks in and lowers boost to near zero. It sucks. However, the MHD coupled with the xHP flash turns this off. The car will brake boost to 12-14 PSI and when you launch, its violent. So be careful with it but it squeals the front tires and explodes forward. The newest stage 3 xHP version doesn't work. it shifts into second and third while brake boosting. Use the next to latest version and it's fine.
Best launches I have seen are brake boost to 10 PSI in M1 and shift to 2nd at 5500. The XI will cut a 1.75 and there's more in it but I'm afraid at this level of breaking something.
      06-04-2017, 01:12 PM   #11
JUST8AV8
JUST8AV8's Avatar
Good to note. I appreciate your feedback and experience.
      06-05-2017, 08:40 PM   #12
blown07
blown07's Avatar
202
Drives: 335i
My method is brake boost in M1 to around 2200 to 2500 and then let the transmission shift by itself from 1st to 2nd. After that I manually shift at 6500.
335i FBO,Meth,JB4,Sutphin flash,LSD,GCLites 11.25@127.4 on NT05R
335xi FBO,Meth,JB4,Sutphin flash,VTT stage1 11.38 1/4 - 7.30 1/8th - 3.35 0 to 60 @ 0C
      06-14-2017, 01:55 PM   #13
JETmn
Drives: 2011 335i xDrive Msport
2011 335Xi  [0.00]
Jeff, do you recommend replacing the mechatronic sleeve at any point as preventative maintenance? I just passed 100k miles.
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
      06-14-2017, 02:01 PM   #14
Yes, that is likely the most important thing to change aside from the trans fluid itself.
JETmn245.00
      06-19-2017, 04:30 PM   #15
NiNeTyOne
Touring cars rock
Drives: e91 330xi / 997 GT3 Cup
If the CDV on the manual cars is any indication of how the BMW engineers are thinking about the cars, I'd be VERY reluctant to launch one of these without a remapped transmission.
You may want to talk to the guys playing with the transmission tunes to see what the 1st and 2nd gear clutch engagement is programmed to do before you tear your auto up like that.
      06-23-2017, 09:31 AM   #16
CDV was designed to reduce drivetrain shock/smooth engagment at the sacrifice of premature clutch wear.
      06-23-2017, 02:21 PM   #17
Underground6t9
Underground6t9's Avatar
317
Drives: BMW 335xi, Lexus is250
Is this app only available for android? Im really interested in it.
|instagram@underground6t9|
      06-23-2017, 10:31 PM   #18
PN3UMA
PN3UMA's Avatar
Drives: 2015 M235i
Pretty sure XHP is only Android.
      07-04-2017, 11:32 AM   #19
Kaoshan
Kaoshan's Avatar
Drives: 2016 550i
I'm glad I found this thread. Was actually about to post my own but searched a bit. I just ran my e90 X Drive 6AT a few weeks ago, and could not get a solid 60ft at all. I think my best 60ft was a 2.05 ish.
The car has a Dinan STG 3 tune, Alpina trans flash and BMS filters. I was pretty disappointed because I figured it had a 1.9 60 ft and low 13 second time-slip.
But, ended the night with a 13.6 @ 103 and that 2.05 60ft. I just did sport mode and brake boosted it a good bit. Maybe I was a bit overzealous with a low 13 sec time?
2010 M-Sport E90 XDRIVE 6AT
BMS DCI / MHD STG 1 / XHP STG 3 / Fuel-It STG 2 / Strong-Flex Bushings
      07-04-2017, 11:46 AM   #20
mojobmw_e90
380
Drives: 2014 E63S
All traction off completely, s1, brake boost at 2500,and take off, let transmission change into 2nd on its own and after that manual shift urself at 5700 2-5th.pulled multiple 1.7 60ft with this setup. Ran 12.2@110 with just jb4 and intakes
      07-04-2017, 03:53 PM   #21
CanadianTSi
CanadianTSi's Avatar
207
Drives: 2014 535 xDrive Diesel
Car should run that bone stock. Are you sure it actually has the Dinan tune?
      07-10-2017, 12:57 AM   #22
NFiftyWon
97
Drives: E90 LCI 328 X-Drive
When i launch from sport mode @~2k rpm the torque dips hard at the end of 1st gear and 60 fts very slightly faster
