05-27-2017, 06:38 PM | #1 |
Rep 10
Water Temperature Reading
For anyone who has added either one of the aftermarket gauges or a bluetooth OBDII sender to their phone have you noticed the coolant temperature readings and do they seem unusually high? After start up cold my temp will run up as high as 229F degrees. I will occasionally see it lower into the 180F on an easy run down the highway but no reason that the range should be that great and I am wondering if it is the sender, my gauge or normal to run that hot.
