05-24-2017, 03:38 AM | #1 |
639
Rep 665
NVLD issue please help
Do all BMW cars come with the NVLD module or just the US specs?
I have the P147D code on, after trying to install a DV+. Restored all the hardware to stock, the P147D is still on. I have the European spec M2 and my guys cannot locate the NVLD module, anyone know where it is? Or if I should check other things? Thank you, David |
05-24-2017, 08:32 AM | #2 |
49
Rep 857
Hey there,
I took a look at some diagrams on realoem and it looks like the NVLD is equipped on some euro-spec cars, but depends on region. For example there is a diagram that shows korea only models, and it shows the nvld pressure switch. If your car has it, it will be attached to the charcoal canister and the fuel tank ventilation line. It will be near the right rear wheel underneath the car most likely. It may even be behind the fender liner by the fuel filler neck. Other models equipped with the NVLD have had service bulletins out to replace the nvld pressure switch, so they can go bad randomly. It's worth looking for, Good luck! Last edited by RPIpower; 05-24-2017 at 08:44 AM.. |
05-24-2017, 12:33 PM | #3 | |
639
Rep 665
