05-20-2017, 12:39 PM | #1 |
653
Rep 1,922
Drives: 2011 e91
Drag strip woes
I went to the drag strip last night, and while nobody there was running spectacular times, I noticed that compared to last year I was having a hell of a time trying to get traction.
The track was Castrol Raceway in Edmonton, elevation somewhere around 3800 ft. Temp started at ~60 and went down to about 50. Car was running Shell 91, tires at 22psi. The problem was obviously traction. It was too cold to hook up. But I did notice that when I got to about 5500 RPM in 2nd, the car felt like it shut off. Didn't do that in 3rd or 4th. Best time of the night was 13.79 @105. Best 60' was 2.28. How do you guys with manuals launch? Last night I found running with the car in sport+ ran the best. I'd hold about 2000 RPM and feather the clutch out, otherwise it was massive wheel spin or wheel hop. Last year my best et was 13.05 @114, I think my 60' was around 2.1.
2011 E91
2016 M2 - Sold 2014 X1 - Sold 2002 Land Rover Discovery II - 3" lift & 33s |
05-28-2017, 07:12 PM | #2 | |
54
Rep 99
Quick question though, was it the same track both times? Even if traction was a issue the loss in trap speed is what has me a little confused. Losing 9mph in the 1/4 is brutal. Any mods? |
05-28-2017, 08:02 PM | #3 | |
460
Rep 1,133
05-29-2017, 09:53 AM | #4 |
54
Rep 99
05-29-2017, 08:22 PM | #5 |
653
Rep 1,922
Drives: 2011 e91
Same track. Only mod is the catless down pipe. I think it has the compressor wheel spinning up too fast, the MAP is probably reading too much boost then wasting.
I don't have this problem on the street, but I'm also not opening up like this in traffic. I think I need a tune to allow for higher boost/faster spooling. Then I can data log to see what's happening. I've heard a few others talking about the car going into limp mode because of down pipes, maybe mine is just on the verge.
2011 E91
05-29-2017, 09:22 PM | #6 |
4178
Rep 3,075
Drives: 991.2 Porsche GT3, BMW E46 M3
Garage List 1987 BMW 325is [10.00]
2004 BMW X3 [6.50] 2018 Porsche 911 GT3 [10.00] 1974 BMW 2002tii [10.00] 2004 BMW M3 [10.00] |
Are you capturing any type of data right now? With a Performance Analyser or Torque App for example?
I see you are running 91 octane, how good is the gas in your area? I am thinking like someone else mentioned above, might be pulling timing because its sensing knock?
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii |
05-29-2017, 10:44 PM | #7 | |
54
Rep 99
05-30-2017, 07:22 PM | #8 | |
653
Rep 1,922
Drives: 2011 e91
I didn't have any problems in any other gear, just second
2011 E91
05-30-2017, 07:28 PM | #9 |
4178
Rep 3,075
Well I have done pulls where the car lost traction and I feel like its DSC kicking in to get the rears to hook again. It does happen mostly in 2nd gear while running in Sport+ where DSC is just partially off. But it feels like its just cloaong the throttle or something because the car basically halts the acceleration for a full second.
Follow me on IG
05-31-2017, 06:47 PM | #10 | |
54
Rep 99
Something is up for sure though, the loss of mph in the 1/4 is substantial. People have posted dyno's with a little e85 added and they pick up power and get a cleaner powerband from just the 91oct piss fuel. |
