05-17-2017, 11:14 PM | #1 |
198
Rep 501
Drives: 2015 M4
Any special trick to unplugging oem flaps?
So, had the flaps open on a cold start - found the plug on the drivers side, but for the heck of me, I could not remove it - is there some trick to removing it? Definitely different from my M4 whereby it slid out relatively easy.
Thanks...
2018 R8 V10+ - Ara Blue/Gray
2022 MS Plaid - Red/White (Daily) 2021 Alfa Stelvio - Red/Black 2013 135is - LeMans Blue/Gray 2003 M5 (56k miles) - CB/Black |
05-18-2017, 03:53 PM | #2 |
BMW Newb
582
Rep 903
It should just slide out once you compress the clip section...at least it did for me.
05-18-2017, 08:04 PM | #3 |
198
Rep 501
Drives: 2015 M4
It was in really tight - eventually gave after some tugging Thanks...
