E90 headlight eyelids yellow / discolored!
05-15-2017, 08:35 PM | #1 |
36
Rep 216
Hey, so I'm in the process of doing an LCI conversion to my '06 330xi. I found a great deal locally on adaptive xenons. The issue is the lenses need work. Mainly the eyelids - they look yellowed and discolored. I'm not sure if the usual wet sand and polish would get them back to normal shape or there's some defect with the eyelids that wouldn't be resolved with a sand polish.
Anyone have a similar experience? I attached a picture to show what I'm talking about. Thanks! |
05-15-2017, 09:00 PM | #2 |
198
Rep 562
No amount of sanding the lens will get rid of that because it's the actual eyelid plastic on the inside that's discoloured. Only fix is to disassemble the headlight and replace the eyelid or just paint it.
05-15-2017, 09:08 PM | #3 | |
70
Rep 125
Follow this video cause you cant bake those open like you could with the e92's.. And to seal them back up use this..
IG: RockoOmazing Youtube.com/RockoOmazing |
whyzee1251678.50 |
05-15-2017, 09:39 PM | #4 | |
uber driver
114
Rep 657
Check out this video. It's how BavGruppe opens their headlights. |
05-15-2017, 09:46 PM | #5 | ||
70
Rep 125
05-16-2017, 12:33 AM | #6 | |
uber driver
114
Rep 657
One heat cycle will not get the sealant for the sedan headlights soft enough to remove, but it does soften them for you to fit the tools in. Trust me, I've opened headlights by cutting the upper lip before and I loved how quick and easy it was, but it's worth it to do it the clean way with the hook tool. That way you don't have dirt sticking to exposed butyl. Also, using the hook tool is not going to mess up the lip like prying it with a flathead does. It completely avoids that and it for sure looks better than a cut lip and exposed butyl. Good luck OP! Take your time if you do open up those headlights. |
05-16-2017, 12:46 AM | #7 |
70
Rep 125
Ah ok yeah after watching the video I thought to myself thats not butyl lol the hook tool would work but man thats a royal pain what I did to avoid dirt getting on the butyl was just cut the excess off so the only butyl you have showing was under the lens, but you're right man, spending the extra couple hours and having that little lip will look untampered with lol
05-16-2017, 01:16 AM | #8 | |
uber driver
114
Rep 657
That's smart by cutting out all the excess butyl. I was afraid the lights were gonna condense so I just left on a bunch of excess and wrapped vinyl around it to keep everything in place. |
05-16-2017, 01:22 AM | #9 | ||
70
Rep 125
Ps. And hypothetically speaking lets just say you do want to shell out.. you're better off just buying a another headlight if you're going to spend that much lol
05-16-2017, 06:43 AM | #10 | |||
36
Rep 216
I think I'm going to pass on these headlights. The price isn't good enough to justify the work. I figured if it was a outer surface issue it'd be a simple fix. |
05-16-2017, 10:44 AM | #11 | |
BimmerPost Supporting Vendor
469
Rep 4,938
The other option is you can put a vinyl decal on the outside of the lens to "cover" the eyelid. that would be a very inexpensive option.
05-16-2017, 04:20 PM | #12 | ||
36
Rep 216
05-17-2017, 01:59 AM | #13 |
58
Rep 192
Yellowing plastic usually means it has poor anti-uv protection (when injection molding they didn't add any/enough additives to the resin to make it last in sunlight). So if you want to go the LCI headlight route you'd need to use "sunblock," either a film or a coating (Meguiar's headlight restoration, etc).
01-09-2020, 07:56 AM | #14 |
2659
Rep 6,290
Old bump to hopefully get info. I wanted to restore my E92s they have that same brow. I'm wondering if the brow is the same material as the lens. Anyone confirmed using headlight restoration kits on it and coming out nice? Or a new eyebrow piece is needed.
If the restoration work, what did you use to keep it's from yellowing again? Protectants in headlight kits only last up to 1 year. |
01-15-2020, 01:02 PM | #15 | |
uber driver
114
Rep 657
