05-15-2017, 11:20 AM | #1 |
Joint Chiefs of Staff
24165
Rep 190,725
BMW B46/B48/B58 Tune Comparison
Today; I would like to write about the different piggyback options available for the BMW new F chassis B48/B58 engines. This market is over-saturated with tunes priced from a couple hundred dollars up to a couple thousands. Not all tunes are equal, which ones are worth it and which ones are not? Read this post and decide for yourself. Burger Tuning (BMS) B48/B58 Quick Install/Uninstall JB+ How: Burger Tuning JB+ connects to Tmap sensor only. This is the simplest B48/B58 tune on the market. Pros:
Cons:
Price $199 Burger Tuning (BMS) B48/B58 JB4 stage 2 How: Burger Tuning B48/B58 JB4 stage 2 connects to TMAP, MAP and OBD. It also comes with flex fuel connectors for E85 users. Pros:
Cons: Long install time (45 minutes). Price: $529 Dinan B48/B58 Sport Performance Tuner: How: Dinan B48/B58 sport performance tuner connects to MAP and Tmap sensors. Pros: Easy install (5-10 minutes) Adjustable boost Bluetooth capability Cons: Does not suppress CEL code from high flow downpipes No datalogging capability No code reading capability Price $299 Active Autowerke Active8 Tune How: Active8 connects to boost pressure sensor, Manifold pressure sensor, crank position sensor ( rpm pick up point) Pros:
Cons:
Price: $729 Thank you for reading. Dinan Stage 1 will be added to this comparison next.
https://x-ph.com/sale/ Phone number 702-494-9435 Last edited by mike@x-ph.com; 06-29-2017 at 03:42 PM.. |
06-29-2017, 03:42 PM | #2 |
24165
Rep 190,725
Active 8 tune added
09-20-2017, 02:19 PM | #3 |
40
Rep 375
Drives: 2019 Mazda MX5 Miata Club/BBS
Do any of these get rid of rev hang in a manual 230i?
01-04-2018, 08:11 AM | #4 |
14
Rep 73
Hi Mike, is it possible / okay to use a F Series N55 JB4 on a F Series N20 engine? Apparently, BMS' JB Stage 1 can be used interchangeably across all engine types. Just wondering if that still applies to the JB4 since the device looks the same, except that maybe the FW and maps would need to be changed from N55 to N20? Thanks for any info and clarification.
01-04-2018, 11:33 AM | #5 | |
24165
Rep 190,725
Does not apply to the JB4. Its engine specific tune (different board).
