05-13-2017, 12:14 AM | #1 |
757
Rep 1,835
Drives: 2020 X4M CS
True E85 pros/cons...Must Read for EWG N55's on OEM Fueling
OK I'm sure I'll take a lot of heat from people repeating what they heard from some one else who doesn't fully understand ethanol and why IMHO it SHOULD NOT be run through the stock M2 FUEL SYSTEM OVER 20% (30%) AT MOST.
First off I think ethanol is a great way to add power if done right and think it's great for cars designed for it. And I'll try to keep this short and simple. Pros: Cheap Only fuel thus far widely used not reliant on petroleum High Oxygen content which makes for added power Higher Octane Rating than 93AKI (Over 100) Cleans carbon build up on valves (Unfortunately not on BMW Direct Injection Engines) Also in the conversion of a liquid to a gas (bc of ideal gas law) it absorbs large amounts of heat vs gasoline (its boiling and vaporization points, it expands much more absorbing much more heat) Cons: Attracts and holds water or hydrophilic Lowers MPG (Because it's about 30% less potential energy) INDIRECTLY gas stations when tested often mislead consumers w/ lower ethanol content than advertised. Super corrosive to certain metals, and mildly corrosive to all known engineering material aka fuel pumps, hoses, etc Lighter by volume than gasoline so it separates and often goes to the bottom of the tank. Has a stoichiometric level of 9.xx:1 AFR Or LAMBDA of 1 (Due to the molar Oxygen content in ethanol) Ethanol requires about .7 Lbs/BHP/Hr vs .5 For Gasoline (sometimes more for higher VE or Volumetric Efficiency engines) Ethanol IS CORROSIVE. It attaches to the hydrogen in water molecules and creates acetic acid...Acetic acid breaks the carbon from steel and aluminum and other metals especially with high carbon content...Also some rubbers and plastics.... ..The more moisture or water present, the more acids are produced....a few things effect the rate of corrosion. The velocity in which it contacts the metal, the temperature of the ethanol (at 200 degrees Fahrenheit ethanol is extremely corrosive to almost all metals) and the carbon content of the metal...What does this mean steel is worse off than iron, return fuel systems are damaged faster than variable pump pressure non return systems (because the pump operates at 100% all the time thus gets hotter, the velocity of the ethanol through the pump is high and constant, and being recycled the fuel is basically being moved through a heater and it's constant motion is conductive to higher temps, moving parts corrode more quickly than static parts...pump will wear faster than a tank) .. Bottom line is while ethanol vs. 105 octane race fuel ethanol will make more power. Port Injection ethanol is a great tool as well as TBI or even CPI like many of us use meth. They are only one molecule apart and almost chemically twins. However studies show methanol actually will wear internals of ICEs up to 15x's faster than ethanol or gasoline... BUT, in an engine with a BSFC of 0.6 lbs / hr to make 1 BHP will usually take about 30-50% VOLUME of ethanol to make 1 BSHP. Hence a LAMBDA of 1 for pure ethanol is about 9:1, gasoline is 14.7 (At sea level)... Because the oxygen content is so high and remember air is only around 14% oxygen, and that is the only thing used in the air to promote combustion, even though we use twice the volume the combustion is much more powerful but you will get less MPG. Fuel pumps work on VOLUME! We all know the M2 has a HPFP that almost maxes out at the boost levels we all target! So if we're having fuel starvation with 93, e85 blends will make more hp @ low rpm (which is where our cars make all of our HP & TQ..Higher RPMS We will A. misfire from a absence of fuel and thus cylinder injection shutdown or worse B. detonate from a sudden super lean condition 20:1 (hot, dense mix) less likely due to cooling properties and octane of ethanol and BMW Safe guards, not a non intentional fuel cutoff.... Very best case those running ethanol 50% will diminish their fuel pumps life much faster due to the fact it has to pump almost twice as hard to struggle to maintain a stoichiometric mixture. Our pumps can barely supply the gasoline at 18+ Psi, let alone ethanol. And cavitation on the impellers of the not treated metals is likely, over time, or even short term in some cases. 93 octane with exogenous (Port Injection, Throttle body or Charge Pipe injection) meth or ethanol injection has all the benefits of running e30, and none of the pitfalls...And this doesn't even go into the corrosion it can cause and the moisture it invites into your fuel system( especially those who run their tanks empty often) Feel free to add why I'm wrong or right or pros/cons I might have forgotten. I just felt so many were running a fuel in there car that neither BMW nor Terry Burger approve of at higher than 30% without fuel upgrades that don't exist yet for our engines. (Update: Many Upgraded Ethanol solutions are now available, from XDI-35/XDI-60...the later being required for full e85. And Fuel it LPFP upgrades, or simply buying a Walbro 450 or higher LPFP Fuel pump and swapping it with the right adapters out of your In tank Fuel Pump Assembly) Thanks for reading...
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 Last edited by DKX4///M; 10-14-2020 at 01:55 PM.. |
12
Orange fever2351.00 FSociety3812.50 DragonGate71.50 SeanWRT3179.00 jeff@autocouture965.50 chris7197334.00 ddk632585.00 BAN_M2C4185.00 eksigned139.00 thatBimmerBloke872.50 ///MPhatic13862.50 Altra265.50 |
05-13-2017, 12:23 AM | #2 |
2351
Rep 2,829
Drives: E36M,E46M,E90M,X5M,i3,M2,i8
you brotha are right !
seen it with my own eyes. playing with e85 stock Fuel pumps succkkk!!!
BMW I12 i8 Frozen Yellow- H&R springs, 22" Radenergie F10 Monoblock Forged /// F87 M2 Aw -Vorsteiner Aero Kit, VFF-107,Macht Schnell-Springs,VF-Engineering/Hex tuning Stage Two,ER DP,Stock Exhaust,Drop-In Bmc Filter,AA Intercooler,FTP Charge pipe+boost pipe/// Wish list :Mexico delivery 2024 BMW M2 (G87) |
DKX4///M757.00 |
05-13-2017, 10:02 PM | #3 |
1161
Rep 1,726
As with all things in life, you gotta pay to play.
That was a good educational read. I have a friend running some bolt-ons in his GT-R using e85. However, not really working on the fueling. He's enjoying his new found HP, at the moment, but I think his block is taking beating and is only a matter of time before it grenades. |
FSociety3812.50 |
05-13-2017, 10:18 PM | #4 | |
757
Rep 1,835
Drives: 2020 X4M CS
Most of us that spend thousands on engine mods to get 100 hp on a car that any normal huMann would be more than content w 400hp. When we find a cheaper fuel that instantly bumps us up 30 hp it's tough to resist (even when Ur aware of the detrimental effectso hahaha c |
05-15-2017, 07:14 AM | #5 |
3179
Rep 2,577
Ethanol is very popular in GTR R35 world. There are many off the shelf E85 build packages of different stages available from many established tuners in North America.
In addition to being corrosive to various components, Ethanol requires different plug gapping, one of the things that compromise daily drivability, which counts as a con in my book. I am not a fan of that with BMWs, though in preparation for a drag race, Ethonal is definately one of the easier things you can do, for sure E30 won't break anything within half a tank of gas. At the end of day, going extreme with a BMW for drag race is meaningless anyway.
Lemania 2320
05-15-2017, 06:47 PM | #6 |
BimmerPost Supporting Vendor
24201
Rep 190,807
You make a lot of good points which is why E85 everyone advises that E85 level are kept low on stock fueling systems.
Couple things to note: E85 lowers MPG but it is also cheaper so it ends up being the same. I ran E60 for years on my car, not even one single problem. I always went with what BMS suggested in terms of max mixtures.
05-16-2017, 08:51 AM | #7 |
966
Rep 13,780
Excellent write up, Absolutely Excellent.
Ethanol is great for the modding world for setups designed to run it. As you said, it is highly corrosive to systems not built for it. |
05-16-2017, 10:32 PM | #8 |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
2004 Matrix XRS 6MT => 2008 VW R32 DSG => 2012 Audi TTRS 6MT => 2018 BMW ///M2 6MT
I'm an IT guy by trade and tech nerd by choice. I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway. I'm also a fan of aural pleasure. |
DKX4///M757.00 |
05-17-2017, 09:26 AM | #9 | |
538
Rep 752
05-17-2017, 10:07 AM | #10 |
2050
Rep 1,200
Been running mostly pump E85, some E98 and some race blends of Ethanol over the past 5 years with over 40k miles logged...probably more. Just put on 500miles this weekend driving all around San Diego. It's a great fuel and all the new gen BMW mixing to get an estimated E30/50/60 or whatever blend is unfortunate because with a flex fuel sensor and full E85 is where you'll see the big gains in performance.
If your fuel system is built for ethanol then it will last. PTFE fuel lines and regulator/pumps designed for E85 are recommended (not required). A small cost for the gains to be had. I used to run pump fuel with methanol injection and my flexfuel setup is way better and more reliable. I still have a basic walbro in-tank fuel pump that wasn't designed for E85 and it's doing well...so that just goes to show it isn't so bad. As for plug's needing re-gapping that's false. The only time you need to re-gap is when your ignition system isn't up to the task or something needs to be further optimized in the tune. I've ran gapless plugs for years on the stock ignition system and now an upgraded VAG coil conversion. Basically if you're happy with your car...leave it stock. If you want to modify the car for E85, do it right and go full E85...not all this half blend crap that all the JB Junk guys run. Last edited by Commanderwiggin; 05-17-2017 at 10:19 AM.. |
05-19-2017, 11:59 AM | #11 | |
757
Rep 1,835
Drives: 2020 X4M CS
have u modified your hpfp, if not how are you not dealing with starvation or fuel cut or even pre detonation or any knock? otherwise your right about gapping, if u need to lower your gap your timing is prob too advanced peak power usually comes slighlty after tdc where ignition is obviously easier. |
05-19-2017, 04:41 PM | #13 | |
2050
Rep 1,200
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration 1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder |
DragonGate71.50 |
05-20-2017, 05:24 PM | #14 | |
757
Rep 1,835
Drives: 2020 X4M CS
05-20-2017, 09:22 PM | #15 | |
2050
Rep 1,200
Here's an OLD setup back in 2013. http://forum.e46fanatics.com/showthread.php?t=988544
05-28-2017, 10:34 AM | #16 | |
757
Rep 1,835
Drives: 2020 X4M CS
But you follow your statement with you would need fuel upgrades with a link to an 800whp e46 with a completely redone fuel system top to bottom, and if you actually read it all the way through the Twin 62mm Walbro 400's he has "do not react well to e85, and will likely need to be replaced" Also he's pushing off the top of my head between t the 4 pumps and multi regulator system (all of which is low pressure btw) enough fuel to power a 1600whp car running on gasoline, 93, ms 100, whatever... So I don't get your post, sorry if I misunderstood...Please post a vid of you filling up on e85 from an empty tank and a few 2nd-4th WOT runs...Id like to see how the car protects itself...Maybe an ejection seat lmao
2020 BSM X4///M-2016 BSM ///M2- 2011 668 ///M3 |
Commanderwiggin2050.00 |
05-29-2017, 11:14 AM | #17 | |
2050
Rep 1,200
A stock M2 system with a single pump radium surge tank setup and a basic port fueling setup would likely be more than adequate with a Bootmod3 flash tune setup for 80% E85. Secondly...the link is my personal car which is only running a single in-tank walbro 255 pump feeding the surge tank with two Walbro 400 E85 spec pumps. The in-tank pump which is not E85 spec has been running successfully without issue for over 4 years now. Not sure where you got two in-tank and 4 pumps from. There is a total of 3. There is also only one regulator...yes it's a low pressure system and I never said my system would be the same in an M2. The link was provided at your request to prove validity. If you want a video here's an old one running around 900whp: https://youtu.be/_W4plCsJjVM As for filling up...that's a pretty boring and basic thing to take a video of. I can guarantee I've ran up to 98% ethanol in my system. Running 1000rwhp now on a smaller injector with 80% ethanol straight from the pump. This is also a daily driver believe it or not...I take you for a non-believer.
05-30-2017, 12:07 AM | #18 | ||
184
Rep 214
FSociety3812.50 DragonGate71.50 |
05-30-2017, 08:53 AM | #19 | |
2050
Rep 1,200
06-01-2017, 10:59 PM | #20 |
227
Rep 245
Drives: M2 DCT MPerformance coilovers
not only do you have to have the right gear with E85 but if you want to tune to extract the available power you gotta find the right dyno tuner and trust him with your expensive engine! More power but I suspect less margin for error too.
06-02-2017, 03:40 PM | #21 |
2050
Rep 1,200
Larger margin for error actually. E85 has a way larger window of knock resistance. Can't go wrong with a basic OTS Bootmod3 tune already available for around 400rwhp with current stock fueling. Anything over that needs some additional fueling for reliable operation. Dyno will do 450 but you'll find issues with acceleration forces at work.
DragonGate71.50 |
06-02-2017, 04:41 PM | #22 |
72
Rep 102
Commanderwiggin Awesome info thank you for sharing some light here as the big opposition of E85 from the biased
Are you planning on doing any E85 (max limit test) on your M2?
15' X5M DG, enzotune
17' M2 *** CTS Turbo FMIC, CTS Turbo DP, CTS Turbo CP, CTS Turbo Intake *** Bootmod3 E30 OTS |
