05-10-2017, 10:56 PM | #1 |
841
Rep 2,363
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
New LED Taillights
If these new taillights are like bmw has done for LCI before they should be plug and play. So 2 questions. 1) when can I get a set? 2) will there be black lines?
For those who don't know with the 1 series when the LCI tails came out you could get the black line versions which were smoked out. Made an awesome difference on the 1er.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
05-12-2017, 10:44 PM | #3 |
191
Rep 314
Part numbers will probably be only available once the car comes out.
As for the shadow editions, they are only for for the 1 series and 3 series. Which makes sense since these cars are nearing their end of productions and they need to boost sales with these mini-LCIs. |
05-14-2017, 01:44 PM | #4 | |
446
Rep 780
Drives: 13 GT50014 AW M235i(sold)
Any idea what the pricing was when the 1 series came out lci?
2014 AW M235i Sold
2013 BLK GT500 track pack/ perf pack/ recaros |
05-14-2017, 11:25 PM | #5 | |
841
Rep 2,363
Follow my builds:
Questofthetune445.50 |
05-15-2017, 11:41 AM | #6 |
446
Rep 780
I'm very willing to pay that for a PnP LED styled tailight honestly. I really do feel like that's the one "lower end feature" on the car.
2014 AW M235i Sold
abirmaher840.50 |
05-17-2017, 10:14 PM | #7 |
841
Rep 2,363
Waiting for part numbers on these so I can get a quote and order.
Follow my builds:
05-19-2017, 07:50 PM | #8 |
1330
Rep 2,214
I'd be up for a pair as well, if the price it right. The MK7's have an LED option for ROW cars, and they're $600usd. I wouldn't pay more than that, personally.
Tuned in for updates. |
05-19-2017, 08:42 PM | #9 |
446
Rep 780
Eagerly awaiting!
2014 AW M235i Sold
05-20-2017, 09:32 AM | #10 |
3848
Rep 2,873
Makes sense to spend for the right look. They are, after all, the only part of your car anybody should be getting a good look at, right?
05-22-2017, 08:47 AM | #11 |
841
Rep 2,363
Hear hear!
Follow my builds:
05-22-2017, 12:03 PM | #12 |
3848
Rep 2,873
I was thinking more about this over the weekend, as I was stuck in traffic behind a Maserati (around here, you don't get to say that often). I was really struck by how generic their taillights are (ditto for several MB's, but perhaps I was just starting to fixate - one this morning I couldn't tell if it was a Civic or an MB). Makes me glad ours have at least some unique styling, and all the more reason to mod it up a bit more.
R0ME0519.50 |
05-22-2017, 12:39 PM | #13 | |
446
Rep 780
2014 AW M235i Sold
WillOs7.00 |
07-16-2017, 11:27 AM | #15 |
97
Rep 107
Done.....
They lights itself will fit plug and play but there is another connector (6 instead of 8 pins) and pinout for the new ones. Part numbers: 63217420991 left 63217420992 right 61132359993 connector (you need 2 pieces) Your dealer should be order it. Price is approx. 400 - 500 USD. There are no blacklines available for the 2 series. |
07-16-2017, 11:42 AM | #16 | |
Kingslayer
411
Rep 1,479
Previous Cars: 2008' 135i, 2010' 328i, 2013' 328i, 2016' M235i, 2017' X1, 2019' M240i Current Cars: 2019' X3, 2021' M3 Comp |
07-16-2017, 12:05 PM | #17 | |
26
Rep 39
Wow! So the connector is a plug in play or what?
07-16-2017, 12:10 PM | #18 |
15
Rep 92
I also have a set of new tail lights here and hope to find the time to install them soon.
It is not completely plug an play since the new ones have a 6 pin plug, but it is not that much work to change the wiring. Some coding is also necessary, this I got coded on my car (as I said, the light are not installed yet, so no warranty for this): Rückfahrscheinwerfer LED 3061 RFS_L_KALTUEBERWACHUNG -> nicht_aktiv : Disabling cold bulb checks for Rear Left Reverse Light. 3061 RFS_L_WARMUEBERWACHUNG -> nicht_aktiv : Disabling warm bulb checks for Rear Left Reverse Light. 3061 RFS_L_IS_LED -> aktiv : Setting Rear Left Reverse Light Type to LED. 3061 RFS_R_KALTUEBERWACHUNG -> nicht_aktiv : Disabling cold bulb checks for Rear Right Reverse Light. 3061 RFS_R_WARMUEBERWACHUNG -> nicht_aktiv : Disabling warm bulb checks for Rear Right Reverse Light. 3061 RFS_R_IS_LED -> aktiv : Setting Rear Right Reverse Light Type to LED. MAPPING_RUECKFAHRL_L_PWM_LEVEL_1 13.7V = 89 MAPPING_RUECKFAHRL_R_PWM_LEVEL_1 13.7V = 89 Bremslicht LED BL_L_KALTUEBERWACHUNG nicht_aktiv = 00 BL_L_IS_LED aktiv = 01 BL_L_UE_SPG_SCHUTZ nicht_aktiv = 00 BL_R_KALTUEBERWACHUNG nicht_aktiv = 00 BL_R_IS_LED aktiv = 01 BL_R_UE_SPG_SCHUTZ nicht_aktiv = 00 MAPPING_BREMSL_L_PWM_LEVEL_1 13.7V = 89 MAPPING_BREMSL_R_PWM_LEVEL_1 13.7V = 89 Fahrtrichtungsanzeiger auf LED FEM_BODY/REM 3061 FRA_H_L_KALTUEBERWACHUNG nicht_aktiv Rear-Left Turn Signal Bulb Cold FEM_BODY/REM 3061 FRA_H_L_WARMUEBERWACHUNG nicht_aktiv Rear-Left Turn Signal Bulb Warm FEM_BODY/REM 3061 FRA_H_L_IS_LED aktiv Rear-Left LED bulb **May cause CheckEngine Light** FEM_BODY/REM 3061 FRA_H_R_KALTUEBERWACHUNG nicht_aktiv Rear-Right Turn Signal Bulb Cold FEM_BODY/REM 3061 FRA_H_R_WARMUEBERWACHUNG nicht_aktiv Rear-Right TurnSignal BulbWarm FEM_BODY/REM 3061 FRA_H_R_IS_LED aktiv Rear-Right LED bulb **May cause Check Engine Light** MAPPING_BLINKER_H_L_PWM_LEVEL_1 13.7V = 89 MAPPING_BLINKER_H_R_PWM_LEVEL_1 13.7V = 89 Nebelschlusslicht LED NSL_L_KALTUEBERWACHUNG nicht_aktiv = 00 NSL_L_WARMUEBERWACHUNG nicht_aktiv = 00 NSL_L_IS_LED nicht_aktiv = 00 NSL_R_KALTUEBERWACHUNG nicht_aktiv = 00 NSL_R_WARMUEBERWACHUNG nicht_aktiv = 00 NSL_R_IS_LED aktiv = 01 MAPPING_NEBELSCHLUSSL_L_PWM_LEVEL_1 13.7V = 89 MAPPING_NEBELSCHLUSSL_R_PWM_LEVEL_1 13.7V = 89 |
07-16-2017, 12:28 PM | #19 | |
841
Rep 2,363
Follow my builds:
07-16-2017, 12:30 PM | #20 |
97
Rep 107
The connector will fit the new lights but as I wrote there is another pin allocation at the new ones.
So you have to pin out the cables from the old connector and insert it to the correct port on the new connector. Coding is also needed that's wright. I thought that's clear cause of led and old halogen. |
Averga311.50 |
07-16-2017, 01:41 PM | #21 |
15
Rep 92
07-19-2017, 01:31 PM | #22 | |
995
Rep 598
