HID Flickering
05-08-2017, 10:40 AM | #1 |
Rep 13
HID Flickering
Hi all
Recently went to an HID Specialist shop to install HID's on my BMW E90 (2008). They fitted 6000k bulbs and upgraded my high-beams to Cobra bulbs. However - when the keys are in the ignition and the car is started they flicker around 6 times. I purchased a new canbus ballast only to find you cannot replace this with the kit they've supplied. Any help would be greatly appreciated. |
05-08-2017, 10:42 AM | #2 |
3441
Rep 79,211
Where are these lights fitted? Low Beam? Fog Light?
The flickering could be a bulb check or a weak battery - depending on the location. |
05-08-2017, 11:40 AM | #4 | |
3441
Rep 79,211
You can code out the bulb check if it bothers you. The car sends tiny pulses of electricity to check the bulbs to make sure they are working. |
05-09-2017, 05:17 AM | #5 |
Rep 13
I'll try coding out the bulb check on the high beam LED's and side light LED's tonight. Thanks Jeff
05-09-2017, 11:29 AM | #6 |
3441
Rep 79,211
05-11-2017, 06:01 AM | #7 |
Rep 13
