Track day pads
05-06-2017, 10:15 AM | #2 |
Life is better with burnouts
97
Rep 611
Drives: BMW
Dont bother. Go with your stock pads and have fun.
princelybug59.50 |
05-06-2017, 01:13 PM | #4 |
169
Rep 212
Cool Carbon work well, as do Hawk pads. Depending on what track, even as a Novice, you can work your OEM brakes pretty hard. A brake fluid change if it has not been done recently is a must. Fluid will let you down before pads will on track.
2011 335i Sport, M3 control arms front/rear, ECS Tuning rear trailing arms, Bilstein HD's, StopTech BBK, Drexel LSD, Dinan camber plates, FBO's with Cobb Stage 2 tune, Corsa exhaust, 18x9 D-Force, 255/35 R-S4's
05-06-2017, 03:37 PM | #5 |
109
Rep 235
Negative. I'm not going out there and kill myself with brakes that wont hold up. I can make them fade on back roads with this heavy pig. I am sure as hell not taking stock brakes to the track.
Also, please dont assume that I have no prior track experience. I'm leaning towards PFC 01 or Pagid RS19 yellow. I'm not sure that either is enough brake pad for such a heavy car. |
05-06-2017, 04:34 PM | #6 |
401
Rep 1,425
EBC yellow
3IM . Okada Plasma Direct . Euro Ram Intake . AA header (Pending) . PE . 2nd Cat Delete . F30 340mm 6 pot . EBC Yellow Stuff . StopTech SS Brake Line . BMW Performance CF Strut Bar. 219M . PSS
05-31-2017, 02:57 PM | #8 | |
137
Rep 819
05-31-2017, 05:34 PM | #9 | |
Touring cars rock
351
Rep 907
The only way you're really going to know is to paint the rotors and monitor temps. If you don't get enough heat into the system the 19's will chew through rotors fast (as will any improperly spec'd pad running under temp). The RSL19's have a better range but they are hard on rotors if you don't get heat into them before you pound them. If I was doing basic HPD track sessions I would go this route as they are predictable across the entire heat range from 100° to well past the boiling point of your fluid. Just be gentle with the pedal force till you get some heat into the rotors. RS42's would be the go to choice if you find yourself out on a cold day, but they won't have the heat tolerance of the 19's, so once it's even warm out, get them swapped out. They are my go to rain pad. Benefit of the Pagid's is that I've seen no compatibility issues when swapping back to Centric Posi-Quiet 104's or 105's after the track session. With Brembo, Hawk & EBC I found transfer layer compatibility issues when swapping from race to street pads. Make sure you have a rotor hone just in case if you develop judder from the old pads. You never know. I also like the feel of the Pagids better than most other pads on track. Torque brake fluid has served me well in street and race applications for a few years now as well.
Sportwagon Daily: I've done some stuff.
TEC109.00 |
05-31-2017, 11:12 PM | #10 | |
Rep 10
TEC109.00 |
06-05-2017, 06:01 AM | #11 |
50
Rep 243
I posted a little review on the pad/rotor combo I added last year. Haven't tested on the track, so it may not be very relevant for you, but fwiw they feel great on spirited runs.
Current: 08 335xi Sedan - ST Suspension Coilovers - M3 Front Strut Brace - COBB Stage 1 - ECS Tuning Chargepipe + BOV - aFe Stage 2 Intake - Precision Raceworks Ignition Coils
