BMW M3 Forum (E90 E92)
BPM
      04-29-2008, 08:51 PM   #1
Socale92
DCT Test Pilot
83
Drives: ????
will brembo bbk fit oem 18?
sorry for the noobish question but was hoping somebody would enlighten me...t.i.a.
      05-05-2008, 02:24 PM   #2
KonigsTiger
Racying Dynamics
KonigsTiger's Avatar
118
Drives: E92M3 RS46 Club Sport, others
Nop, the BBK will fit 19" and only some 19" for that matter.
      05-05-2008, 02:36 PM   #3
edlms
edlms's Avatar
10
Drives: E92 M3
is it the 405s that won't fit or the 380s as well?
i'm concerned cos my stock oem 18s are meant for track use and will need the brembos to fit...
thanks.
cheers
      05-05-2008, 02:43 PM   #4
KonigsTiger
Racying Dynamics
118
thanks.
cheers
405's will simply not fit, 380 do not fit on some wheels.
      05-05-2008, 02:47 PM   #5
edlms
edlms's Avatar
10
Drives: E92 M3
in that case, how would i go about checking if the 380s will fit the stock 18s?
has it got to do with the ET, as well as the wheel diameter?
thanks.
cheers
      05-05-2008, 02:50 PM   #6
hakaida442
hakaida442's Avatar
Drives: 11 Porsche 911 Carrera GTS
get a template from the brake manufacturer to see if the wheels will fit.
      05-05-2008, 02:50 PM   #7
KonigsTiger
Racying Dynamics
118
thanks.
cheers
Well, I ordered my wheels from HRE and they make them to fit the brakes. I currently have 20" Breyton wheels and those do not seem to have any clearence issue either. The issue is with the ET on the 20" wheels and depending on the wheel design, the 19" diameter may be and issue to both. I just wrote my Brembo contact and asked, will see what he says about the 19" wheels and BBKīs.
      05-05-2008, 02:56 PM   #8
edlms
edlms's Avatar
10
Drives: E92 M3
noted.
thanks guys...
cheers
      05-05-2008, 02:59 PM   #9
KonigsTiger
Racying Dynamics
118
noted.
thanks guys...
cheers
From my Brembo contact:
QUOTE
"It will fit all 19" wheels simply from the fact that most wheels are based on the OEM specs and, as you know, it is confirmed that the BBK fits the OEM 19" wheels already."
UNQUOTE
Still, please check that you donīt have any issues when you order!
      05-05-2008, 03:03 PM   #10
edlms
edlms's Avatar
10
Drives: E92 M3
QUOTE
UNQUOTE
woah... that was quick... thanks.
could you ask him about the stock 18s too? thanks again...
cheers
      05-05-2008, 03:17 PM   #11
Lewis@MWDesign
261
Drives: 2010 BMW Z4 3.5i 6spd
cheers
Here are the templates you can use to see if the bbk will clear the 18s.
      05-05-2008, 03:21 PM   #12
KonigsTiger
Racying Dynamics
118
Thanks Lewis!!! Edlms, that is my Brembo contact by the way!! Hahaha!!! And where I bought my BBK as well!
      05-05-2008, 03:51 PM   #13
hakaida442
hakaida442's Avatar
The template should be posted in the manuals and guides section too or a new stickied thread should be made concerning all of the people that ask "will BBK fit with these wheels?"
      05-05-2008, 03:54 PM   #14
KonigsTiger
Racying Dynamics
118
Yea, I think thats a great idea!!!! By the way, does anyone know what size are the stock rotors?
      05-05-2008, 04:01 PM   #15
badfish
badfish's Avatar
100
Drives: E92 AW M3
2008 M3  [0.00]
I saw them up close on OC Kid's M3 with the OEM 19s. They just barely fit those wheels. I mean barely.
      05-05-2008, 04:01 PM   #16
hakaida442
hakaida442's Avatar
front: 360x 30mm
rear: 350 x 24mm
      05-05-2008, 04:07 PM   #17
KonigsTiger
Racying Dynamics
118
front: 360x 30mm
rear: 350 x 24mm
Thanks, makes sense! So yes, the 380mm must just bearly fit the 19" and probably does not fit the stock 18".
      05-05-2008, 10:43 PM   #18
edlms
edlms's Avatar
10
Drives: E92 M3
thanks for all the info...
that means that i either have to forego the brembos or get 19"s for the track...
either way, not ideal...
hmmmm...
cheers
      05-06-2008, 09:38 AM   #19
KonigsTiger
Racying Dynamics
118
hmmmm...
cheers
You should be just fine with 19" wheels for the track IMO. I track mine with 20" wheels and beat a number of E46 M3īs, so 19" should be just fine.
      05-06-2008, 10:36 AM   #20
consolidated
consolidated's Avatar
205
Drives: F80 M3
gotta run MPSC or street tires with 19" wheels, not ideal, that's why hardly anyone uses 19" wheels for the track. Toyo is starting to make R888 in 19" but in very limited sizes and availability.
Get 18" and you have your pick of race and track tires including Hoosiers, if your that serious about trackwork, if not then sure, why not 19" or 20" for the occasional track day, you'll just be a bit slower.
      05-06-2008, 01:45 PM   #21
edlms
edlms's Avatar
10
Drives: E92 M3
at this point, i do want to fit the brembo 380mm 6pot front and 4pot rear, but that would render my 18"s OEM wheels (originally intended for track use), 70% stock PS2 tires, brand-new unused PS Cups redundant...
furthermore, by running 19"s for track would mean getting my 5th set of wheels (don't ask... ha ha) and more expensive track tires - more than USD$300 increase for every set of tires. (that's $300 more every two months by my calculations of the frequency of my track sessions)
affordability issues aside, i just don't know...
does brembo have anything that can fit the OEM 18"s and are an improvement over the stock brakes? (of course they do, but any specific recommendations?)
cheers
      05-06-2008, 04:53 PM   #22
KonigsTiger
Racying Dynamics
118
cheers
Ufff!! Tough call. Seems like you really do track a lot, so I do think you may need better brakes. I suggest looking for Brembos that would fit the stock 18”, you know, 355mm rotor with 6 pot piston up front and that ought to do the truck. Donīt really think there would be a huge difference between the 355mm and 380mm rotors as long as the caliper is the same for both and would be an improvement over stock brakes.
m3post
