part number for shorter m3 bump stops....
05-01-2017, 10:14 PM | #2 |
285
Rep 615
Drives: '11 E92 335xi 6MT
E36 M3 front bump stops are part # 31332225377.
Z4 M rear bump stops that you also want are 33507836826. |
05-01-2017, 11:48 PM | #3 |
65
Rep 515
05-02-2017, 08:32 AM | #5 |
245
Rep 1,595
Drives: 2011 335i xDrive Msport
You want the upper shock mounts front and rear too. The rears are very soft and go bad easily. Get the Monroe version for the rear.
2011 335Xi 6AT - VRSF catless DP - VRSF 7" FMIC with turbo inlet pipe - VRSF chargepipe - Pure Stage 1 turbo - JB4 - E30 - xHP Stage 3 - Strongflex tension bushings - Whiteline RSFB - UUC rear swaybar
miker201365.00 |
05-02-2017, 10:44 AM | #6 |
285
Rep 615
I still have my notes from when I did my shocks & springs last year. Here's the full parts list. 2x of everything.
front upper spring pads 31336767500 front lower spring pads 31336764372 front dust boots 31331094749 rear upper spring pads 33536764419 rear lower spring pads 33536764420 Monroe rear upper shock mounts 907984 Monroe rear lower shock mounts 907985 The front upper shock mount is called the guide support by BMW, part # 31306785962. These are often reused depending on mileage. I got camber plates which replace this mount so didn't need it. |
miker201365.00 |
06-11-2017, 07:02 PM | #7 |
202
Rep 749
Drives: 335i xDrive
I have a front pair for sale if interested!
