2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions BimmerCode
      04-25-2017, 10:59 AM   #1
SwolePatrol
44
Drives: 2015 M235i Melbourne Red
BimmerCode
Just used this app on my iPhone to make the following changes:
-Auto-Fold Mirrors on comfort touch lock/unlock
-Windows/Mirrors/Sunroof open/close with FOB
-Legal disclaimer removal
-Ambient lighting 100%
-DRL 100% at all times
-Digital Speedometer
-Show current gear in dash
-M Performance iDrive Startup
-M Performance BC startup
-Door handle lights on during reverse
I would highly recommend this app to anyone. It was super easy to utilize and backs up your settings in case you need to revert your changes.
Probably the best $30 (App) and $12 (OBDII Adapter) spent!
      04-25-2017, 01:14 PM   #2
pz619
3279
Drives: F87 M2C 6MT, Tesla 3
Agreed, I have it and love it.
      04-25-2017, 03:32 PM   #3
Sleslie
Sleslie's Avatar
40
Drives: 2017 230i xDrive
How does this display? Does it show D1, D2, etc in both comfort and sport setting?
      04-25-2017, 05:44 PM   #4
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
I just got this today after reading about it on the M2 forum. It's awesome and idiot proof.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      04-25-2017, 07:10 PM   #5
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
I think it only works in S mode so S1, S2, S3
      04-25-2017, 07:49 PM   #6
orangeglim
Drives: 2019 M2C
2019 M2C  [0.00]
Mine does this already. Maybe its was added in 2016?
      04-25-2017, 10:20 PM   #7
pikcachu
pikcachu's Avatar
1403
Yeah could probably be standard now. It used to just show D/S for me
      04-26-2017, 08:44 AM   #8
Quantumn
Drives: 17' M240i & 16' X1
SwolePatrol Did you have to buy a special OBDII adapter or can I just get any with Wifi?
The website states "A Vgate iCar 2 Wi-Fi OBD adapter is required to connect to your car."
I have a bluetooth one so I assume it wouldn't work
      04-26-2017, 08:56 AM   #9
BEM-S4
BEM-S4's Avatar
I have low power BT which I prefer for torque pro and leave it in the car all the time. I can confirm it does NOT work for this. Just get the recommended wifi one I think it was like $20. No sense in f*cking around and trying to save $5 or something, since 1. you know the recommended one works and 2. the LAST thing you need is the connection to crap out in the middle of coding.
You make your changes then hit "code" and during that time I have no idea what would happen if you lose connectivity but I cannot imagine it being good.
2022 Macan S
Appreciate 2
      04-26-2017, 09:18 AM   #10
Quantumn
Thanks for the reply man!
I don't want to brick my car, so I'll pay for a quality adapter.
Do you have a model you recommend?
Their recommendation received quite low rating...
https://www.amazon.com/Vgate-Functio...s=Vgate+iCar+2
skitsos83.00
      04-26-2017, 10:48 AM   #11
SwolePatrol
44
That model you linked is the exact one I used. Not sure about the low rating. I bought it on the amazon 'dot' de website and it had a better rating. Works like a charm!
      04-26-2017, 10:56 AM   #12
BEM-S4
BEM-S4's Avatar
Yeah that's the one I used too, worked like a charm just plug it in and connect to wifi. You don't need to mess around with their software or app, Bimmercode takes care of all of it.
For torquepro I use this one in case anyone is interested, I tried a few and this was the best. Leave it in the car all the time with no issue. Only suggestion I would make is pain the thing black, the clear housing with lights gets distracting at night with the foot well lit up.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2022 Macan S
      04-26-2017, 05:19 PM   #13
T4455
12
Drives: m3
great info, this beats paying someone $100+ for their service.
Is there anyway to do video in motion at full speed with this?
      04-26-2017, 06:45 PM   #14
BEM-S4
BEM-S4's Avatar
Keep in mind that $100 could go poof when you go to dealer if they update your software or something and you lose all changes. This way you just restore from a backup in 5 mins.
2022 Macan S
      04-26-2017, 11:03 PM   #15
ggggbmw
433
Drives: 2017 M2 Manual
This sure looks simpler than dealing with the hacker underground of E-Sys. I started down that path, but have to get a new(er) laptop with enough memory. And I need to rebuild the ethernet adapter that came mis-wired.
Still, E-Sys does everything.
Are there any key capability areas that E-Sys has that this Bimmercode doesn't cover yet? It seems like iCarly is missing a lot of things, and this OBD based product might have some of the same limitations.
      04-26-2017, 11:13 PM   #16
Vyruz Reaper
Reverse Homer
Vyruz Reaper's Avatar
Drives: ///M240i
I also jumped on this couple weeks ago. Coding was a breeze. I haven't tried advanced mode yet. I'll dive into that next week when I get a chance.
Also, how do you make a backup? Just once every time you make changes? Does it make an auto backup for you? That part wasn't clear
      04-26-2017, 11:16 PM   #17
Vyruz Reaper
Reverse Homer
Drives: ///M240i
I got vide in motion to work but it only changed it to ~40mph then it cut out.
Maybe in the advanced mode there is a way to increase he mph higher? I'd have to double check pikcachu 's cheat sheet google Doc. You can use that as a reference for advanced coding.
Only problem is it's a cluster fuck navigating advanced mode in the app
      04-26-2017, 11:22 PM   #18
pikcachu
pikcachu's Avatar
1403
I believe in the latest I-step versions there is a max speed that can't be bypassed.
Maybe check with Almaretto he is usually up to date with the latest of the latest
      04-27-2017, 10:44 AM   #19
Ft_LaudM235i
Ft_LaudM235i's Avatar
36
Drives: M2 Competition
2014 M235i  [0.00]
Just ordered the Vgate, I can't wait to try this!!!
      04-27-2017, 10:55 AM   #20
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
VIM on ID5/ID6 is locked greater than 63 kph due to change in bitmask. To achieve at greater speeds, you use either script activation or hardware bypass.
      04-27-2017, 05:26 PM   #21
Nyorky2428
Nyorky2428's Avatar
90
Drives: 2016 M235i MT
I'm on board with the BimmerCode bandwagon, got my Vgate today and tried it out. Works exactly as advertised!
If you play with the Climate Control settings, it needs to calibrate. Make sure it calibrates all the way (let it go long enough) otherwise you can't turn off the fan... easy fix with a full recalibration
      04-27-2017, 06:24 PM   #22
pikcachu
pikcachu's Avatar
1403
Wonder how this BimmerCode works when BMW releases a new I-step... but I'm no expert...
2addicts
