M2 Technical Topics > Suspension | Brakes | Chassis > Best street and occasional track suspension
      04-21-2017, 03:58 PM   #1
Chaslieb
14
Drives: 2017 LBB M2
I am looking for a suspension that is best on the street and occasional track use. Looking for a setup that will tolerate potholed streets without teeth rattling and still be good if I have a hard turn. There does not seem to be much information but the Dinan coilover kit is reputed [by Matt Farrah] to be softer than stock and the Ohlin road and track bills itself as able to quickly soak up a bump and quickly rebound. I really value comfort for a daily driver over the occasional track day so that is where my priorities lay. It may be that I keep all stock and just put on some front camber plates so my front tires are not destroyed during a track day, but I would welcome advice on the best setup that is either adjustable or progressively sprung so that I can enjoy the ride on the hellish streets of Brooklyn and get the most when I get to the track.
      04-22-2017, 07:59 PM   #2
UltraMagneticAL
Meh
UltraMagneticAL's Avatar
926
Drives: M3CS & Cayman S
2019 BMW M3 CS  [0.00]
2018 X3 M40i  [0.00]
2017 BMW M2  [10.00]
either of those would be good. i have the kw v3 and run it two clicks softer than the "normal" setup for daily driving.
      04-22-2017, 09:00 PM   #3
S1monQc
224
Drives: '18 AW M2
Ohlins
      04-22-2017, 09:29 PM   #4
Wangspeed
51
Drives: BMW M2
I run Ohlins with custom front and rear spring rates. 448/782, I think is what they came out to. There is no doubt that it's stiffer than stock, but it does absorb the big bumps pretty well.
If stock is pushing the comfort level for you, then I would advise plates only.
      04-22-2017, 11:38 PM   #5
HP Autosport
BimmerPost Supporting Vendor
Drives: F80 M3
How much stiffer over stock would you say with your particular spring rate combo? Where do you have your dampers set at? Ohlins R&T is can be tuned to ride very nicely as well.
      04-23-2017, 07:06 AM   #6
Wangspeed
51
Drives: BMW M2
I normally keep them at 13 clicks off full stiff.
8 clicks was perfect on track.
      04-23-2017, 01:04 PM   #7
HP Autosport
Drives: F80 M3
Have you tried 15 to 20 click from full stiff? I bet that will ride close to stock if not better.
      04-24-2017, 02:17 PM   #8
champ_87
Drives: 2017 BMW M2 DCT
A dumb noob here. Plates? Does this refer to aftermarket camber/caster plates? If so, how would they increase the comfort level? Thanks
      04-24-2017, 04:07 PM   #9
Jevi Javi
Dominican Republic
80
Drives: e46 M3 + G05 X5
they dont. I think he meant to JUST use the stock suspension with aftermarket camber plates.
      04-24-2017, 10:02 PM   #10
Wangspeed
51
Drives: BMW M2
Correct. They add a minimal amount of NVH.
      04-24-2017, 10:05 PM   #11
Wangspeed
51
Drives: BMW M2
I like how the car rides and handles on 13 clicks. My wife and kid are more sensitive to this sort of thing. I have a pretty high tolerance. Still rides better than my Cobalt SS with sealed sphericals and UHMW bushings everywhere.
I would personally hesitate to advise folks that Ohlins on a softer setting "rides better than stock". I'll try it just to see what it's like around 15-16 and report back on this thread.
      04-25-2017, 07:43 PM   #12
Chaslieb
14
Drives: 2017 LBB M2
Totally looking forward to your report
I was considering the Ohlins but have read from others that they love it on the track but not as a daily. This may be because it is set too stiff, but looking to see what you think with it dialed down. If you have the jack out anyway and the wheels off, why not try at the softer settings on a bumpy road too?
      04-27-2017, 01:28 AM   #13
Bee Pee
Bee Pee's Avatar
United Kingdom
1761
Drives: AW M2 DCT
An alternative to camber plates could be to use alignment correction bushes in LCA and tension struts that are on car adjustable and add about <1 deg of front camber
Superpro do both - below is camber adjustment bushes for LCAs
http://www.superpro.com.au/find/supe...999501545/vid-
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      04-27-2017, 05:01 PM   #14
HP Autosport
Drives: F80 M3
Better than OE ride is definitely possible. We helped a F8x M3/4 owner achieve that goal with proper selection of springs.
F87 M2 is lighter with a shorter wheel base so even lighter springs may be needed to get the same results, but not impossible.
Here is the link:
http://f80.bimmerpost.com/forums/sho....php?t=1354107
      04-27-2017, 07:04 PM   #15
ryem3
ryem3's Avatar
Drives: 2020 MB M2 CS
Yes, he said the Dinan is more comfortable than stock. However, how is that possible? The Dinan kit is adjustable springs only. No shocks. Do they have a full kit? It isn't on their website.
      05-03-2017, 09:27 PM   #16
Wangspeed
51
Drives: BMW M2
Alright, so I tried 16 clicks off full stiff, that's 3 clicks softer than I normally run, and I really dislike it. I'm surprised how much of a difference it made. Yes it takes some of the harshness away, but in return, the car has an unnatural feel to it. I'm not really sure how to explain it. It isn't the typical underdamped feeling.
So back to 13 clicks for me.
      05-04-2017, 05:31 PM   #17
Jevi Javi
Dominican Republic
80
I think for $2,300 the M performance suspension is tough to beat.
I went to the track a couple weeks with the factory settings. I was able to do 2 sessions but I was already a second faster than the original suspension. Local track is short, just 2.4 km.
then Yesterday night, I changed the rebound and compression shock settings to full soft. And the ride is pretty comfortable. I am now under the impression that the cars ride is more compliant than what it was when stock.
      05-05-2017, 01:47 PM   #18
Chaslieb
14
Drives: 2017 LBB M2
Seem pretty pricey for a nylon bushing that costs as much as camber plates and perhaps as much or more to install- also not apparently user adjustable between greater and lesser camber setting- more of a set it and forget it kind of thing. Are you using them and do you find any advantage to them?
      05-05-2017, 01:50 PM   #19
Chaslieb
14
Drives: 2017 LBB M2
When you say "unnatural" did it seem the car was floating at that setting? Was it bouncing up and down on the springs? Hard to get at what you did not like.
      05-05-2017, 03:49 PM   #20
Bee Pee
Bee Pee's Avatar
United Kingdom
1761
Drives: AW M2 DCT
Not using them personally - I'm running F8x LCAs and TS on my m135i
      05-05-2017, 10:45 PM   #21
Wangspeed
51
Drives: BMW M2
It feels almost like it is underdamped, but different. The steering response also slows down. Not feel, but the responsiveness. It took all of 5 minutes to decide I was never going to run that setting again.
      05-12-2017, 04:34 PM   #22
Chaslieb
14
Drives: 2017 LBB M2
Strangely, Ohlins used to use a much lower spring rate
From a sale listing I found:
Ohlins Suspension For 2007-2013 BMW M3 (E9x) - BMS MI40
product detail information
Spring Rate: Front: 60 N/mm // 343 lbs/in. // 6.12 k/mm - Rear: 120 N/mm // 686lbs/in. // 12.23 k/mm
This on a car with a curb weight of 3,704 to 4,145 lbs.
Strange then that the spring rate for the M2 which has a curb weight of 3,450 lbs. should be so much higher.
I wonder if the dampers are so different from this vehicle to those for the M3 that lower rate springs are not recommended?
Search this Thread:
Advanced Search
m2
